Failed Ca. Smog test
Old Dec 27, 2018 | 09:24 PM
skinnyt's Avatar
skinnyt
Originally Posted by mtwoolford
If you fail a CA smog test, first things first, ignition tune up, plugs, plug wires, rotor, rotor cap. Once all that's known to be good, you can start chasing other things.
what year how many miles?
id do the first things first, ignition tune up, plugs, plug wires, rotor, rotor cap. Once all that's known to be good, you can start chasing other things.
like 02 senores ???
if u got a maf senor ?
temp senor ?
that's the first things I would have looked at
Old Dec 28, 2018 | 10:57 AM
Z51BOB's Avatar
Z51BOB
Cruise-In II Veteran
Your blm of 151 shows the car is on the edge of being too lean. That will raise combution temp and nox. Assuming your egr is clean and working correctly, verify your fuel pressure is at spec (too low will cause a lean tendancy). And verify that the base timing is at spec — too much base advance will drive both hc and nox up.
Old Dec 28, 2018 | 02:10 PM
mtwoolford's Avatar
mtwoolford
Originally Posted by Z51BOB
Your blm of 151 shows the car is on the edge of being too lean. That will raise combution temp and nox. And verify that the base timing is at spec — too much base advance will drive both hc and nox up.
As noted before in other posts, make sure that the outer ring on the balancer hasn't shifted. In other words, when you verify that #1 piston is at TDC on the compression stroke, that the balancer is at 0 degrees. Those outer rings, can and do shift.
Old Dec 28, 2018 | 02:45 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Originally Posted by CorvetteMike2004
Replaced the egr valve , egr solenoid, and egr temp sensor. Put a new cat on. Still failed emissions due to high NOX. Ran a scan on my vette today. Its going into closed loop. Rich Lean flag goes rich/ lean. Cross counts 171, Block learn 151. The engine runs good. Still haven't checked plugs. EGR duty cycle is working. Seems like I have weak vacuum though. Any suggestions?
I don't think my egr is opening up. I'm still failing emissions. Does my ecm control the egr? Running a scan does not show any opening egr signals. No codes. Any ideas?
It reads like you have done quite a bit of troubleshooting already and replaced suspect parts. But you don't provide any information in your profile for modifications. Do you have headers? New high flow exhaust? Did you modify anything since you last passed a smog test?
You might want to look up what type of EGR valve your model/year has. Positive backpressure, negative backpressure or just straight vacuum operated EGR?
Oh and something to look at is your tune as a leaner running engine makes more NOx but less HC and CO. Look at the emmisions graphs for fueling and you will see it's a tight operating band to keep all 3 emissions products low. So you might want to consider a slightly richer tune if you are lean at all now.
Just FYI I have been reading that California emissions have been getting tighter even for older cars meaning that the standards today might fail a car that passed previously.
Let us know more about your car if you still want help.
