Sway bar bushing ??
Old Oct 28, 2002 | 11:13 PM
blkc6z51's Avatar
blkc6z51
Default Sway bar bushing ??
Just like to know if the bushing that go on the end of the bars,
do you need to press them on? Thanks
Richard :cheers:
Old Oct 29, 2002 | 12:09 AM
VetteRacer282's Avatar
VetteRacer282
Default Re: Sway bar bushing ?? (blk90)
It helps to have access to a press. They can be done without one, I used a socket and a bench mount clamp (I forget the offiicial name of it).
I did that to my 24mm rear bar, I am going to be pressing the 26mm bushings since my brother has a press... its easier for sure..
:cheers:
Matt
Old Oct 29, 2002 | 04:04 AM
LEERJ1's Avatar
LEERJ1
i replaced mine about a month ago. horrible noise over bumps because it was completely worn and busted out. metal to metal. anyways, i had to use a press to get it back in. there is a piece that connects it to the sway bar and another bar but if you take that off and press it in it should take about 30 mins all in all. the connection piece is about two inches long so you cant miss it. veru easy with a press. :seeya :flag
To Sway bar bushing ??
