Eliminating A/C Brackets on a 1986 Corvette
Hello Folks,
I have a 1986 Corvette TPI engine installed in my 1947 Plymouth. Drives the Mopar purists nuts.
Anyway, it still has the A/C mounting bracket installed with some sort of idler pulley instead of the compressor (see picture attached)
I would like to completely eliminate that bracket, since it interferes with the inner fender well, and I won't be needing AC, at least for the near future.
I realize that this would require a different belt, and possible re-location of the belt tensioner. Has anyone else done this before? Can this be done with factory parts?
Any and all information regarding this modification would be greatly appreciated.
Thanks in advance!
Thanks in advance!
I'd like to hear from anyone who may have done that. Does the serpentine belt care how it tensioned, in other words, would this affect the wear of the belt, or the drive friction against the pulleys?
Thanks again to all.
Pro Mechanic
You have to retain the reverse wrap on the water pump...which requires some kind of pulley to the passenger's side of the WP.
I did what you're doing. I used an '88-'95 Chevy truck/TBI bracket for the alternator, chopped the AC bracket (to minimally support the tensioner), installed the truck crank pulley and spaced the WP pulley to align. WAY cleaner and less "sprawled" out...and it was cheap.
Before:
And after...
[img]https://www.corvetteforum.com/forums...7&d=1524755936
Why in the hell doesn't ^this^ work anymore? WTF!
See details HERE.
Before:
And after...
See details HERE.
Pro Mechanic
I can't remember. I can look when I get home tonight....
-Tom
-Tom
It can be even simpler.
I modified the upper alternator bracket on my 1984 to function as an old style tensioner.
The water pump is an aftermarket short style with 'V-belt' rotation. The stock pulley works just fine.
I have been running like this for years without any problems.
It is difficult to get a good picture with all the piping in the way.
Pro Mechanic
Still don't have the size, but I snapped a pic of the belt part number that you can use. I also snapped a few other shots for you to look at...
The '88-'95 TBI truck bracket...
Rear view showing the '88-'95 rear gusset, pump, etc.
kbuhagiar (11-28-2018)
Since yours isn't in a C4 chassis you might actually be able to adapt a 'complete' accessory drive from a different GM - you might visit some local JY and look at anything GM 4.3, 5.0, 5.7 in most anything that's not passenger car. A non AC I'm quite sure moved the alternator to high and right location for nearly all of those applications. I'm thinking S10, Astro and maybe full-size vans. A non-AC 4.3 tensioner is quite complicated I think.
A 'talented' GM parts guy could easy show you various configurations on paper for most any 4.3, 5.0 or 5.7 for years '88 - '95
Tom's idler varies just a bit from yours - yours is done with a R4 GM compressor and his originally had a 'denso.
I'd say you've many options.
How about a few more snapshots of the car!!
Pro Mechanic
Pro Mechanic
Beautiful! Love the interior and engine compartment! Thanks for sharing.
I've a couple friends who were big on 'Mayflowers' That's a good bit of 'RED' for sure.What do you have for alternator and power steering pump now? Saginaw from the L98 Corvette and it's reservoir or modified? Steering 'gear box' or steering rack? What brand and part # is the water-pump you're using now? You mentioned not being interested in changing pumps!! Standard Corvette pulley?
Since I made my original post it has dawned on me that I may need AC sooner than expected (relocation to a hotter climate). Nonetheless, If that happens I will utilize a compact Sanden compressor, and probably have to re-do the entire serpentine drive system anyway, so I'd much rather conserve costs - and efforts - right now. I'm more interested in trimming - or eliminating - that AC bracket since it is ugly, and interferes with the inner fenderwell, causing an occasional rattle or buzz.
But, like I said, I'm easily swayed...
