Diff upgrade
Old Nov 27, 2018 | 07:14 PM
jayjones's Avatar
jayjones
Default Diff upgrade
Is D44 the only choice? For what power level is that sufficient? What do guys with d44's upgrade to?
Old Nov 27, 2018 | 08:30 PM
383vett's Avatar
383vett
A straight axle is one option.
Old Nov 27, 2018 | 08:32 PM
Hot Rod Roy's Avatar
Hot Rod Roy
I may be hard to believe, but the Ford 9" is the diff. of choice. Of course you loose the IRS, but that's all part of making the rear end so much stronger!
Old Nov 28, 2018 | 07:50 AM
C409's Avatar
C409
..... I've been pounding the D44/IRS with approx. 600hp for a while … the worst I've done is break a few U-joint caps … presently running a custom spool …..
Old Nov 28, 2018 | 06:17 PM
JoBy's Avatar
JoBy
Hammerhead 12-bolt center section:
https://www.corvetteforum.com/forums...section-2.html
To Diff upgrade
