hot start problem
Old Oct 29, 2002 | 02:29 PM
qkvette's Avatar
qkvette
Default hot start problem
Anybody experience this ? my car will not start after you've driven it for more than an hour and try to restart within 5-10 minutes after shutdown.
i've wrapped the new starter, but the problem seemed to have gotten worst sincce i put the cats back. i'm thinking of wrapping the cats to reduce the heat next to the starter. what do you guys think ?
any advice appreciated.
thanks,
joel
Old Oct 29, 2002 | 02:35 PM
vader86's Avatar
vader86
Default Re: hot start problem (qkvette)
Be a little more descriptive, what exactly is it doing?
Is it cranking and cranking but no fire, or does it do nothing.
Old Oct 29, 2002 | 02:39 PM
qkvette's Avatar
qkvette
Default Re: hot start problem (vader86)
it doesn't crank at all. after about an hour or so of cool down, it will crank with no problem.
i've replaced the starter, with a brandnew ac delco, but I'm also looking at some power master starters from scoggin dickey, which it claims to eliminate hot start problem. i would hate to buy another starter, since this one is only a week old.
thanks,
joel
Old Oct 29, 2002 | 02:50 PM
vader86's Avatar
vader86
are you sure its your starter? are you getting spark to the cylinders? what about fuel?
leaky injectors cause hard hot start problems, but they dont usually act like this
Old Oct 29, 2002 | 02:59 PM
FoolCrzy's Avatar
FoolCrzy
if it doesn't crank, it's not spark or fuel..could be a bad cable near the starter that heat affects. if it's a new starter, i doubt that's it...it does sound heat related though.
Old Oct 29, 2002 | 03:01 PM
qkvette's Avatar
qkvette
when you turn the key, you can hear a click around the starter area.
and if you were to put an electric fan to blow air aroound the area to cool it down, it would startup sooner.
do you guys think, i would harm anything, if i put the same thermal barrier on the cats, as i did on the starter ?
thanks again,
joel
[Modified by qkvette, 2:25 PM 10/29/2002]
Old Oct 30, 2002 | 05:35 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Putting thermal barrier on the starter won't help. It needs to cool off. Put it only on what's generating the unwanted heat.
Old Oct 30, 2002 | 02:36 PM
qkvette's Avatar
qkvette
Default Re: hot start problem (CentralCoaster)
thanks.
should i order the the thermal barrier or a set of header wraps to put around both L & R cats to be consistent.
i'm not sure what it would do. hope this doesn't shorten the life of the cats. i've heard putting header wraps, shortens the life of the headers. would it do the same on the cat housing.
joel
[Modified by qkvette, 4:39 PM 10/30/2002]
To hot start problem
