OIL QUESTION
Old Oct 29, 2002 | 04:12 PM
CorvetteGeo's Avatar
CorvetteGeo
Cruising
Default OIL QUESTION
I dont know if my car is running DINO or Synthetic oil. How do I tell?
The car has around 20K mi on it so if it is running DINO oil would it be advised to change it to synthetic or just leave it where it is? Im worried about leaks that the synthetic might find if I change.
Thanks guys
[Modified by CorvetteGeo, 8:13 PM 10/29/2002]
Old Oct 29, 2002 | 04:38 PM
pwrful c4's Avatar
pwrful c4
Default Re: OIL QUESTION (CorvetteGeo)
G.M. RECOMENDS SYYN.OIL. I DONT THINK IT WILL LEAK.I USE MOBILE AND HAD KNOW PROBLEMS :seeya
Old Oct 29, 2002 | 04:57 PM
Barrier's Avatar
Barrier
Default Re: OIL QUESTION (pwrful c4)
I switched mine at 98k on my'86. no problem. I think the leak fear stems from the very first synthetic blends. I have switched to synthetic on all my vehicles, including a 25 year old 455 ci Olds engine with no problems at all, only benifits. Cars run cooler and use less oil than before. I have used Castol and Mobil 1.
Barrier :)
Old Oct 29, 2002 | 05:37 PM
hngacurv's Avatar
hngacurv
Default Re: OIL QUESTION (Barrier)
I don't know what was ran in mine before I bought it, but it now has Mobil 1 with no problems.
Old Oct 29, 2002 | 05:42 PM
Rob90's Avatar
Rob90
Go ahead and switch to full synthetic.
Old Oct 29, 2002 | 05:51 PM
Ender85's Avatar
Ender85
Default Re: OIL QUESTION (Rob90)
If you just bought the car (and thats why you don't know) change the oil regardless and start using the oil/filter you like (Mobil 1 5w-30 is recommended). Also, whats up with your name? Isn't that blasphemous here? :lol:
:seeya
Old Oct 29, 2002 | 06:05 PM
CorvetteGeo
Cruising
Default Re: OIL QUESTION (marthpodi)
Thank you ryone for replying and I feel good about using MOBIL 1 now.
Old Oct 29, 2002 | 07:02 PM
vader86's Avatar
vader86
you should switch over to Mobil 1, it doesnt sludge up and can take more abuse, plus since it seems like your car sits alot it would be better all around.
I had dino originally in my 86 when i bought it, switched over to mobil 1, no more sludge at ALL, cleaned out everything in the oil pan built up over the years. Did develop a slight oil leak though, but nothing major.
Mine burns 1qt every 2500mi or so.
Old Oct 29, 2002 | 10:33 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I have 88k on my vette so I use 20/50 wt. oil...vavoline extended oil...
This works great for me.....How many miles are you running...I also have an aftermarket oil kooler...so I run the ford oil filter.....
:cool: :cool: :cool: :cool:
Old Oct 30, 2002 | 05:17 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: OIL QUESTION (oldace84)
I put in Mobil1 10-30, and developed some new leaks. My oil pressure is pretty high, always has been. It seems I'm leaking past the valve seals, and a teensy bit on the intake (haven't gotten around to retorquing it) and it's even seeping out the drain plug.
:crazy:
To OIL QUESTION
