Rear bushing change
Now it rides like a piece of crap lumber wagon. I feel every bump every pebble and crack in the road. It just ruined the ride of my C4. I'm seriously thinking about NOT changing the front bushings.
Has anyone else experienced this.
Anyone have any thoughts in the matter?
However it didn't help with the rough ride. it ride like a Ford Fiesta now.
Maybe I need to o down a rough gravel road and soften up those hard poly bushings. lol
Curious, did you remove the sway bar?
If you did is it possible you installed it upside down?
I did this once by accident and the car rode like a buck board.
No I did not remove the sway bar. I did one side at a time because I was not in a situation where I could do a complete tear down.
This is just my assumption, but I think I was use to the old ride with the worn out bushing and didn't realize how it should ride with a tight suspension.
i feel good when road has good condition, In case of bad road maintenance i suffer
My biggest complaint is that when I did my bushings 20 years ago they did not have graphite built in like the newer bushings do. My cars both squeak like crazy in the cooler weather so I squirt dry lube Teflon or silicone into the joints about once a year usually in the spring.
My C3 rides the stiffest but it has a lot to do with being originally a L-71 Corvette. I have KYB gas shocks on my C3 and I can tell heads or tails on a coin when I run it over, it can be brutal. Time for a better shock for me.
After all of my experiences I would hesitate to call the switch to poly bushings an "upgrade". Next time I will use plain old rubber as these bones are getting older and don't like the buck-board ride that I was stuck with after the install.
Merry Christmas and Happy New Year with your Corvette!
Chris
https://www.corvetteforum.com/forums...-bushings.html
these are what I am going to buy as I restore the Dana 44 I am putting in my car.
https://corvettesalvage.com/product/...set-1984-1996/
It is just as you and I (M.M.) discussed the rod end sway bar links, but I will have to study the motion. Those pin top shock mounts utilize a rigid bushing, however, that forces the motion soley into the shock, there is not a piece of rubber squishing before the shock starts to move.
Back when I had the 65, there was still OEM bushings available for it, due to the commonality of parts between the C2's and C3's. I ripped the suspension out and rebuilt it back to factory new and it road superbly.
With the batwing bushings, with either the oem rubber (when it is still compliant) and these new bushings, there is going to be a bit of movement/deflection, but how much ?? I guess how well they are encapsulated will affect them.
I have the beam plates from ZFDoc that I am going to install when I put the D44 in. Those should definitely firm up the c-beam/trans/diff interface and limit some of the movement, so I am hoping that these new bushings will help soak up some vibration but not allow too much deflection.
I can "feel" when a car is not tracking true and it drives me nuts. Very often I have my wife (or son) follow me to see if a vehicle is dog tracking. That is how it feels to me if a car (or truck) is not applying force straight through the middle of the vehicle. There was a specialty alignment shop in the area when I younger (actually still is there). The owner at that time raced, so he understood when I had my alignments set at "even even" and lived with the drift from the crown of the road.
HOWEVER I do agree that for racing purposes, some custom machined and fitted Del-alum bushings would tie it up tight.
I am really looking forward to driving my car when I get all the new suspension pieces in.
Go back in time and revisit this post that Tom put up. (another spot on post for that matter).
https://www.corvetteforum.com/forums...al-member.html
there are a bunch of different points presented in it, I suggest everyone in this thread go back and reread it.
like some of the folks that talked about the beam plates in the thread, I bought them to help spread the clamping load across the aluminum and not let the bolt holes hog out.
one point that I found terribly interesting was the the C4 was originally intended to have a torque tube, but certain difficulties caused it to be delayed until usage in the C5's,
the heim joint suspension that I am putting in (Banski Motorsports) is going to limit the amount of twisting going through the batwing bushings, so as I envision it, the movement is going to be mostly up and down, hence a little cushioning effect not transferring so much road vibration into the car.
Here is a really good read on a C4 suspension rebuild.
https://tech.corvettecentral.com/201...sion-overview/
https://tech.corvettecentral.com/201...shing-service/
https://tech.corvettecentral.com/201...-installation/
