erratic oil pressure gauge
Old Dec 15, 2018 | 03:04 PM
violinsib's Avatar
violinsib
Cruising
Default erratic oil pressure gauge
Oil pressure readings random readings sometimes OK. Replaced both oil pressure switches and no better results. Ran a manual gauge connected for a week and confirmed oil pressure is OK.
Old Dec 15, 2018 | 03:41 PM
84 4+3's Avatar
84 4+3
Start checking wires. Something is wonky somewhere. Iirc the sender grounds through itself so somewhere between the gauge and dash is my bet.
Old Dec 15, 2018 | 06:57 PM
383vett's Avatar
383vett
Both oil pressure switches?
Old Dec 18, 2018 | 12:19 PM
WW7's Avatar
WW7
You should only have 1 oil pressure switch, it should be at the back of the intake manifold on the drivers side....WW
Old Dec 18, 2018 | 12:42 PM
WVZR-1's Avatar
WVZR-1
The OP has mentioned this a 'few' times - a couple occasions in 2014 - I mentioned in one of those threads that since he hadn't mentioned year I assumed that his gauge would likely have been a 'bell shaped" affair. I don't believe I've ever seen the OP mention year specific but through '88 it would have been a 'bell shaped' single wire sender.
In 2014 he mentioned doing a 'mechanical' also.
To erratic oil pressure gauge
