The 1992-93 LT1 had SA rockers and guide plates just like the L98. The guide plates are not hardened nor are the pushrods. The guide plates were for easy engine assembly at the factory.
GM changed the design of the cyl head around the pushrods sometime in late 93 early 94 that made it easier to assemble at the factory.
Will
Will
If you want a stock head - the LT4 heads were probably the best flowing - but they aren't dramatically better than stock LT1 Heads - and you have two other decent options.
1. If you want to stay stock - contact Lloyd Elliott - he is quite good at porting LT1 heads. If you do a search on his name - you'll find plenty of people on the forum have used him.
2. If staying stock isn't a priority - look at a set of aftermarket heads - the AFR heads are probably some of the best out there... Not cheap - but you get what you pay for....
Getting 1.1 HP / cid is relatively easy these days and doesn't require a "big" cam. GM was saying over 400 HP from the LT4 heads - their "Hot Cam" and Headers back in the day & I'm sure that a set of 195cc LT heads from AFR will outflow the LT4 heads every day of the week.
If the motor is apart - you might as well go with a stroker crank and an 0.030 overbore to get a 383. Go with a mild cam and a good set of heads - a bit of porting on the intake and then get someone who is good at tuning, and you should be there and have a nice fat torque curve which is just what you want on the street.
