Stealth Ram Question?
Old Oct 30, 2002 | 05:49 PM
lead_foot's Avatar
lead_foot
Default Stealth Ram Question?
ttt
For those using the Holley SR, what did you do about EGR? Holley says that there is no EGR connection on the SR. How will this affect performance or emissions?
I'm thinking about it for my 89 Firebird. :)
[Modified by lead_foot, 6:02 AM 11/4/2002]
Old Nov 4, 2002 | 09:20 AM
lead_foot's Avatar
lead_foot
Default Re: Stealth Ram Question? (lead_foot)
ttt
How will not having EGR affect everyting?
Old Nov 4, 2002 | 11:30 AM
grumpyvette's Avatar
grumpyvette
leagally it might pose a problem but the engine still passes emissions with the stealth ram if it also did with the stock TPI intake. when my frinds truck went through emmission testing the tail pipe emissions passed just fine with the stealth ram installed.but he was useing a crane #114142 flat tappet hydrolic cam which is milder than mine, lucky I don,t need to go through that this year as it may pass with the roller cam I use but I don,t need to prove it! :D
Old Nov 4, 2002 | 12:14 PM
vettmech's Avatar
vettmech
Default Re: Stealth Ram Question? (grumpyvette)
You won't need the EGR for emissions unless they do a 5 gas (or IM240) test. The only correct way to determine NOX is under load with a 5 gas........ in other words dyno time :lol: :seeya
Old Nov 4, 2002 | 12:26 PM
lead_foot's Avatar
lead_foot
Default Re: Stealth Ram Question? (vettmech)
Here in Arizona we have to pass the IM 147 for pre-OBD 2 vehicles.
To Stealth Ram Question?
