automatic trans, cammed engine and reverse
Old Jan 10, 2019 | 05:22 PM
Went's Avatar
Went
Default automatic trans, cammed engine and reverse
Hi..a friend was in to my store today. We got to talking about the engine Jim Barth is building for me. This friend says the car will have issues backing up with a stock converter. As my 1989 is now, 700R4, stock converter, 3.07 rear end you pull it into reverse and all is normal. He thinks I will have problems with the engine wanting to die with my foot on the brake at idle in reverse. I've never heard anyone say this could be a problem before. True story...partially true?
Thanks guys.
Went
Old Jan 10, 2019 | 05:29 PM
84 4+3's Avatar
84 4+3
Maybe if the idle is low but with a decent tune it shouldn't be a problem. I run a stock stall on a 383 in my truck (1800 stall) and only when its cold does it even think about it. I have a hard time keeping it stopped at a light, it is bouncing off the stall and fights the brakes the whole time. Cam is a 224/230 so not wild by any means either though.
Old Jan 10, 2019 | 08:46 PM
Kevova's Avatar
Kevova
It will depend on the tune. Tuning can compensate for some idle issues.
Old Jan 10, 2019 | 09:35 PM
Went's Avatar
Went
My cam is the Comp Cams 268XFI HR13, 268/276.
Went
Old Jan 10, 2019 | 10:18 PM
84 4+3's Avatar
84 4+3
Went
That's similar to a hot cam. A decent tune and you'll be fine. You should do a stall but I think you'll be fine.
Old Jan 12, 2019 | 08:38 PM
cv67's Avatar
cv67
St. Jude Donor '05
Jim can guide you better than your friend can, stick with what he tells ya. Youll be glad you did.
Old Jan 12, 2019 | 08:53 PM
84 4+3's Avatar
84 4+3
Old Jan 13, 2019 | 03:23 AM
383vett's Avatar
383vett
Jim is one of the best builders around. Why would it make any difference backing up or going forward. It’s the same converter between the engine and transmission.
Old Jan 13, 2019 | 12:17 PM
WW7's Avatar
WW7
My 89 with a 383 and a 218/226/112 Erson cam had no problems backing up without stalling with the stock converter.. I'm running an even bigger cam now with no problem... Your friend is wrong...WW
To automatic trans, cammed engine and reverse
