stumble then stall - strange codes 1986
Check for spark, fuel pressure and injectors pulsing
Turns out to be a bad HEI coil
I was going to pull the ICM and I replaced it about 2 weeks ago already but before I did I pulled the coil because it was less disassembly. It smelled burnt and It checked out bad, open circuit all connections. It must have been intermittent opening up when it got hot but after changing it for a new one it fired right up. I feel pretty confident that I finally tracked it down.
Thanks All
Thanks All
