Help!! Please....
Old Jan 17, 2019 | 04:10 PM
Eddie77's Avatar
Eddie77
Default Help!! Please....
My vette stalls out....if you wait for awhile it will start....but if i unhook battery to reset the car starts right up...note: when the car dies there is no stuttering it just stop running....1988 vette....
Old Jan 17, 2019 | 04:24 PM
3D-Aircrew's Avatar
3D-Aircrew
It would be interesting to see what your fuel pressure does when this happens. If you don't have a fuel pressure gage borrow one from a parts store. Tap into the fuel rail on the passenger side of the engine.
Old Jan 25, 2019 | 04:28 AM
Eddie77's Avatar
Eddie77
Fuel pressure is fine....
again heres my problem:
The car runs then dies...it will turn over but not start...it sits awhile then starts..but if i take the battery off then immediately hook it back up it starts right away...ive taken it to 2 shops and since the service life is not on they cant run a test....help!!!
Old Jan 25, 2019 | 05:12 AM
3D-Aircrew's Avatar
3D-Aircrew
That's definitely not a VATS problem and you say you have fuel pressure so you need to find out if you have spark when you are cranking and it not starting. Pull a sparkplug and ground the treads on the block insulating yourself and have someone crank it. If no spark then you've narrowed down your issue a lot.
To Help!! Please....
