I'm working to change the noisy lifters in my 96. I have all of the bolts out of the intake but can't get it to budge. I've tapped it and I can't really find any convenient place to pry on it. Any tips would be greatly appreciated.
Also, I purchased this car a few years ago with 30k. I've put another 30k on it in the last two years. The original owner told me it's never been apart. I've attached a picture of a couple of the bolt holes (far left and far right holes) in the intake. There seems to be an excessive amount of sealer on the bolts and all of the others. Can anyone tell me if this looks stock?
Someone may have glopped some stuff on to try and stop oil seepage?
If you take the TB off you can stick a large prybar in the plenum and give it a good yank. Kinda overkill but it works.
Update - Intake off but......Do I have a bigger problem
I got the intake and valve covers off. I found a white substance in the valve cover and a smaller amount in the front of the intake. The oil seems fine and I'm not loosing any coolant. Does this look normal?
Thanks for the replies. I pulled the plugs yesterday and they all looked normal. All a little black and no clean ones. When I purchased this car I noticed the cooling fan comes on at 190 also the air filter box was cut open. I was just reading a number of LT1 articles and maybe it's related.
I have the stock thermostat in the car and it runs about 180 on the highway. In the fall and winter it doesn't seem to get much above 190 even in traffic since the fan comes on early. I was thinking maybe this is causing the condensation since the engine never really gets up to the 220 degree range. I've researched but haven't really found an easy way to put the car back to the stock cooling settings.
