broken Dimmer Actuator Pivot
Old Jan 20, 2019 | 10:00 AM
Moved-To-TN's Avatar
Moved-To-TN
Default broken Dimmer Actuator Pivot
My new to me 1985 has a broken Dimmer Actuator Pivot in the steering column I bought the new part and have a service manual coming, bought a used one off ebay was wondering if this is a easy fix or should I seek professional help LOL, What specialty tools would be needed and any tips or even better a video showing how to would be helpful.
Old Jan 20, 2019 | 08:04 PM
Hot Rod Roy's Avatar
Hot Rod Roy
This isn't too tough of a repair. You'll need a tool to remove the steering wheel and a tool to remove the steering column lock plate. These should be available to borrow from your favorite auto parts store.
1. Park the car with the steering wheel straight. (So you can put it back on straight.)
2. Carefully pry off the horn button. Disconnect the wire that clips to the bottom of the horn button.
3. Remove the telescoping adjuster from the center of the column, and install a 5/16"-18 UNC x 1" (SAE!) set screw in the center hole to lock the column in position. (Or make a tool by cutting the head off a 5/16"-18 bolt and putting a slot in the bolt. See photo.)
4. Remove the "C" ring on the center shaft, then loosen the center nut while holding the steering wheel rigid. Don't remove the nut, and don't put the wrench torque onto the steering wheel lock ring.
5. Use the steering wheel removing tool to pop the steering wheel loose from the splines, remove the tool, then remove the center nut. There is a big spring under the steering wheel.
6. Remove the three "bumper rings", put a mark on the top of the white insulator, then carefully pry the insulator from its "snap" fingers in the center of the insulator. Caution: This is a fragile part!
7. Put a mark on the top of the lock plate, and then use the lock plate removing tool to allow you to slide the big "C" ring from the center of the column.
8. After the lock plate is removed, mark the top of the white turn sig cam, and when the turn sig cancelling cam is removed, you'll finally find that one screw that retains the broken t/s lever!
9. Disconnect the cruise control connector under the dash and tie a string to that cable. (See photo.) The string will allow you to pull the cable on your new t/s lever down thru the column.
10. From here, you're on your own! Simple, huh?
Pivot Pin and Column Lock Tools
Cruise Control Connector
Old Jan 20, 2019 | 08:22 PM
Moved-To-TN
yea sounds like fun I had a problem with a steering column on a 89 GMC truck and took it in they only charged a hour labor I think I might do the same
Old Jan 20, 2019 | 08:41 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by Hot Rod Roy
3. Remove the telescoping adjuster from the center of the column, and install a 5/16"-24 x 1" (SAE!) set screw in the center hole to lock the column in position. (Or make a tool by cutting the head off a 5/16"-24 bolt and putting a slot in the bolt. See photo.)
I ain't done one in years but I always thought the set screw required was 5/16-18 and your snapshot (I understand snapshots can be deceptive) appears to be USS. Like I say HRR - I ain't touched one for years. Your stuff close by to confirm?
I'm quite sure I've mentioned 5/16-18 before - If I'm wrong I'd like to NOT do it again!
Old Jan 21, 2019 | 01:39 AM
Hot Rod Roy
My bad! 5/16-18 is correct. I was going by memory, but that's not as good as I thought! What surprised me is that it's an SAE thread in a (quasi) metric car! Thanks for the enlightenment!
(I fixed my blunder.)
Old Jan 21, 2019 | 08:49 AM
WVZR-1's Avatar
WVZR-1
There's much that 'Saginaw' didn't change in steering column fabrication through the years. Forgive me but I don't follow(quasi)? The Telescoping feature operation was pretty consistent back to '69 and column lock feature. 5/16-18 UNC can't get confused!!!
Seems that the OP is maybe leaning towards a 'for hire' fix! Regardless 'for hire' OR DIY I believe I'd consider some additional 'plastics' that are in the upper column. OP is your manual a GM FSM or something other than?
Old Jan 21, 2019 | 10:21 AM
Moved-To-TN
yes I was thinking that while I or the shop was in there I would replace all parts of turn signal switch and maybe a new ignition switch and I have the 85 corvette shop manual ST-364-85 red cover on the way
Old Jan 21, 2019 | 02:42 PM
Hot Rod Roy
Forgive me but I don't follow (quasi)?
When I got into the C4 world (the first Chevy in my life!), I was under the impression this was GM's introduction into the "metric" world. I knew the basic engine was SAE, but if it wasn't threaded into the engine, the parts would likely be metric. So engine brackets were (are) a rather confusing mix of SAE and metric threads, but the rest of the car should be metric. Some SAE and metric threads are so close you've got to be very careful or you'll mess up something! That's why I used the word "quasi". When did GM compete this transition to metric (or have they)?
Quasi: Resembling or alike in certain characteristics or features. Adv. As if. Seemingly but not absolutely.
Old Dec 6, 2025 | 09:33 AM
dburgjohn's Avatar
dburgjohn
I was doing this repair a lot back in the late 1970s and 1980s as a mechanic. I always told my customers "stop using the steering wheel to pull your self out of the vehicle". That was so much nicer than saying "you are fat, get a bigger car".
for any PC police out there, I am fat thus entitled to joke about my own people group. I use the chicken wing maneuver to get out of my Corvette, family enjoys laughing when they see it.
To broken Dimmer Actuator Pivot
