Kill switch
Old Jan 22, 2019 | 03:53 PM
PoprocksC4's Avatar
PoprocksC4
Default Kill switch
Looking to install a kill switch on a 93 C4.
don't want to kill the battery/ stereo/ clock, just disable it.
My dad had pulled the ignition fuse. Worked great. Cranked and cranked but no start.
I'm thinking this would be good circuit to break.
Any thoughts?
Old Jan 23, 2019 | 01:38 PM
Bad Karma's Avatar
Bad Karma
I would kill the fuel pump, so you aren't flooding the engine as you crank. Splice into the trigger wire going to the fuel pump relay and you aren't worried about hi load on a switch.
Old Jan 23, 2019 | 01:55 PM
JoBy's Avatar
JoBy
Or injector fuses
Old Jan 23, 2019 | 02:39 PM
cv67's Avatar
cv67
St. Jude Donor '05
both good choices, plus you can shut them off discreetly. Pulling fuses is a pain and obvious if someones watching. Most alarms are worthless and cause problems later on.
Old Jan 24, 2019 | 03:57 PM
hcbph's Avatar
hcbph
Assuming you just want to prevent it from starting, if the car has a VATS system in it then just put a toggle switch in that wire. When the switch is off it won't read the resistor off the key and won't start. Just a thought.
Old Jan 24, 2019 | 05:26 PM
ChumpVette's Avatar
ChumpVette
Nobody is stealing C4’s.
Old Jan 24, 2019 | 09:25 PM
Hot Rod Roy's Avatar
Hot Rod Roy
That's because the VATS is so good! We all know C4's are really neat cars!
Old Jan 27, 2019 | 10:17 AM
hcbph's Avatar
hcbph
They said that about 2002 Caravans also, but someone stole mine last November.
To Kill switch
