I'm having issues with both my injectors on my 1984. Injector one just dribbles, I plan on replacing or rebuilding this injector. Injector two gives me a constant spray, even when you turn the key to on and it pumps for for two seconds it sprays. When I try to start it it starts right away but begins revving so I turn it off. No codes are given it only flashes 12. I have the factory service manual if someone wants to point me in a good direction to begin reading.
The 84 flashes 1-2 1-2 1-2 then any code and finishes with 1-2 1-2 1-2 IIRC I do not think you have a problem there.
The crossfire revving up on start up sounds to me like a major vacuum leak. These cars are known to have problems with vacuum leaks. The lid of the crossfire manifold is one place to check and the many vacuum hoses around the engine compartment. My current 84 also had a binding in the throttle linkage that would not let the throttle return to the idle.
The crossfire has two different injectors front and back. They are different part numbers so be sure and mark them when you take them out.
If you unplug the one that always sprays, does it still spray? This would eliminate an electrical short. In the case that it doesn't I would say repair or replace. Being new injectors for these aren't all to expensive I would probably just go with new ones. And yes, the front injector flows less than the rear one. The difference is about 1 lb/hr. It makes up for the loss of flow by being plumbed in series.
Good luck with your repair.
I think the engine revving might be because of the injectors dumping fuel. I can almost guarantee this thing has vacuum leaks though. I'm gonna add that to the too do list. The throttle cable was kinked! It looks like it was keeping the injector open about 20 percent. I forced it closed but didn't try to start it.
i unplugged the one that always sprays and it still sprayed. I guess that injector should probably be replaced also. I just got my rebuild kit in the mail, should I send it back and order injectors?
I also found this connection not connected. I'm not sure where its supposed to connect to. It comes from a plastic globe shaped object behind what looks like the vapor canister.
I'm sure this car has some vacuum leaks. I'll have to buy one of those smoke kits to look for it. Maybe that combined with it dumping fuel is causing it to accelerate. I might replace the intake manifold gasket while I have the injectors off.
My throttle cable was kinked. It looks like it was holding the injectors open about 20%ish.
I unplugged the one injector and it still sprayed. I assume that means The injector is messed up right? I just bought a rebuild kit, I night send it back and order injectors if they're cheap enough.
I also found this connection unplugged. It goes to the globe shaped plastic in the front bumper behind what looks like the vapor canister.
yea I'd lean toward injector issue then.
also that appears to be the cruise control servo plug
