Shift Knob Removal - Help please!
Old Jan 27, 2019 | 03:54 PM
WhiteC1's Avatar
WhiteC1
Default Shift **** Removal - Help please!
Tearing things apart today to install short shifter. Having trouble getting the stock shift **** off. Is this threaded hole in the retainer used in some way? Tried clamping vise grips on the retainer but can't get it to budge. Need suggestions. TIA.
Regards,
John
Old Jan 27, 2019 | 04:59 PM
ChumpVette's Avatar
ChumpVette
Somebody has boogered that up previously. I would try taking two screwdrivers and come in from the sides and pry upwards on the wedge.
Old Jan 27, 2019 | 05:03 PM
WhiteC1's Avatar
WhiteC1
I can’t really see a lip that I can pry on. I’m thinking of threading a bolt into the hole and using a slide hammer. The threads go all the way in. Thoughts?
Old Jan 27, 2019 | 05:19 PM
3D-Aircrew's Avatar
3D-Aircrew
Regards,
John
Looks like someone epoxied it on but I don't see haw the button works. There's supposed to be a c clip down there under the epoxy. Maybe try digging out the epoxy and see if the clip is there or not.
Old Jan 27, 2019 | 05:51 PM
WhiteC1's Avatar
WhiteC1
There’s no epoxy. It’s just the reflection in the picture. If I can fit the slide hammer to it, I’m hoping it will pop it loose.
Old Jan 27, 2019 | 06:01 PM
WVZR-1's Avatar
WVZR-1
I've used a 'slide-hammer' before. I had a very short maybe 12" - 14" one. Used that 'shorty' for many things!
Old Jan 27, 2019 | 07:15 PM
RWDsmoke's Avatar
RWDsmoke
Some people drill and tap it so a steering column pivot pin puller will fit it. Works really good that way.
Old Jan 28, 2019 | 03:04 PM
steven mack's Avatar
steven mack
Did you look to see if the factory clip is still on the bottom of the ****?Its recessed into the leather ****.It comes out with a small screw driver.
Old Jan 28, 2019 | 03:11 PM
vader86's Avatar
vader86
Probably someone snapped the C clip that holds it in place and didn't have another one and boogered a way to hold the **** on forever.
Old Jan 28, 2019 | 03:30 PM
RUU's Avatar
RUU
What year? My 96 only has the wedge. It is a soft metal and think threads that small would just strip out if you put any real force on them. I used a small set of vice grips and wiggled it bit by bit until I got enough out to get a solid grip on it and yank it out.
Old Jan 28, 2019 | 03:35 PM
ChumpVette's Avatar
ChumpVette
Damn guys, there is no c-clip on the ZF ****. It is just the wedge that locks it in place after screwing the **** down. You can see from his console/radio it is a 94-96.
Old Jan 28, 2019 | 08:09 PM
WhiteC1's Avatar
WhiteC1
Default Success!
I got the wedge out. The hole someone drilled and tapped into the wedge was 8-32, full depth into the wedge. I drilled out the slide hammer shaft and threaded it 8-32. Them I cut off the threaded portion of a long 8-32 bolt and threaded it into the slide hammer shaft and the wedge. All it took was a couple of light raps with the hammer and it popped right out. I think GM should have done it this way to begin with. All the load is right in line with the wedge, and you don’t have to worry about damaging the leather **** by prying against it.
Thanks to all who offered suggestions! Next step is removing the shifter assembly...
Regards,
John
To Shift Knob Removal - Help please!
