Car dies
Old Jan 25, 2019 | 12:12 AM
Vetteboy31's Avatar
Vetteboy31
8th Gear
Default Car dies
Hi guys,
been fighting this fpr a while maybe some suggestions.
New exhaust, injectors, plugs, wires, distributor, maf sensor, TPI, IAC valve
when maf is connected car will idle the second the throttle is cracked car dies. Verified TPI voltage is correct.
when maf is disconnected car runs fine but posts a maf sensor error (not unexpected).
suggestions? Would obviously rather have everything hooked up.
Old Jan 25, 2019 | 05:52 AM
3D-Aircrew's Avatar
3D-Aircrew
Originally Posted by Vetteboy31
Hi guys,
Welcome to the forum … what year corvette. So you replaced the fuel pressure regulator? Why fight it?... replace it. Easy to check it, pull the vacuum hose off and check for ANY fuel in their … if so it's bad. Here's what a bad one looks like:
Good luck
Do you have a factory service manual?
Old Jan 25, 2019 | 09:27 AM
Vetteboy31's Avatar
Vetteboy31
8th Gear
I have an FSM but it doesnt talk on this much. I've replaced the pressure regulator to no avail. The way this is acting its seems to be telling me there os something in the electronics going on. Another clue might be that when I put the never versions of the MAF sensor in it still throws a MAF error. The older design MAF won't throw a code but that is when the car starts exhibiting this behavior. Oh yes its an 85
Old Jan 25, 2019 | 09:36 AM
KyleF's Avatar
KyleF
Hi guys,
What are you fighting with the FPR? Agree with above, they are not expensive and are pretty easy to replace.
As far as your MAF goes, there is a lot to check into. You should research getting a scan tool set up. A lot of us use a software, laptop, and a USB to ALDL cable. There are many that will work out there, and anythign seeing live data from the ECM will help. This applies to both L98/LT1 cars. You need to see what the computer is seeing. Probing under the hood only tells have the story. You may see the reading out there, but doesn't mean that is reachign the ECM.
To help further, please let us know what year/engine you are working with. My guess would be you have a bad MAF or bad wiring causing a out of spec reading to reach the ECM. Any codes with it plugged in?
Old Jan 25, 2019 | 09:39 AM
Vetteboy31's Avatar
Vetteboy31
8th Gear
Ok the buttons on this keyboard are too close together. Not fighting the FPR meant to say been fighting this for a while.
Old Jan 25, 2019 | 11:40 AM
Vetteboy31's Avatar
Vetteboy31
8th Gear
Ok the buttons on this keyboard are too close together. Not fighting the FPR meant to say been fighting this for a while. Other new items on the car, new Fuel pump, new relay for MAF, all vacuum leaks sealed (those are always fun). What I am seeing here. Since the limp home mode is working really well when the MAF is disconnected it seems like the TPS is working well, The knock sensor appears to be working, The Idle air valve appears to be functioning well
, I have to wonder if the computer program is messed up and needs to be reflashed. Have no idea how to do that with an 85 model. Its pretty easy to do in my 2001 but with this old system looks more complicated.
Old Jan 25, 2019 | 11:58 AM
3D-Aircrew's Avatar
3D-Aircrew
You might want to check out these guys on the electronic fuel injection forum. All kinds of knowledge on tuning these computers since the corvette forum scan and tune forum got removed. I believe the 85 computer is a 1227870. Did you get a code 36 when you put your new maf on? That's the maf burnoff function error and is pretty common with new mafs.
Old Jan 25, 2019 | 12:13 PM
KyleF's Avatar
KyleF
It's common because most new MAFs are thin hot film style and they do not have a burnoff function. Some have a spoof circuit, others do not, and sometimes the spoof circuit to send voltage back to the ECM is not right... CODE 36 is only an issue because the SES light on the dash stays on and it is frustrating.
Without a scan tool to see what the MAF reading is, all you can do is inspect the wiring and swap in another known good MAF to isolate.
The computers in these cars have PROMs and not Flash memory like the newer computers. I am not sure a program on a prom can become corrupt. I have never seen/heard of this before. Anything is possible, but I would say that is a low probability and you need to start checking the MAF circuit.
dmaxx3500's Avatar
dmaxx3500
any codes?
and whats your fuel pressure?
Old Jan 25, 2019 | 12:52 PM
Kevova's Avatar
Kevova
MAF measures amount of entering engine. When it is disconnected ecm defaults to speed density based on tps. There are relays for MAF. MAF uses heated film . If the film is dirty it can give faulty readings and not set codes. Air leaks in duct from MAF to throttle body and vacuum leaks will cause lean conditions , because of unmeasurrd air entering engine. Monitoring MAF, TPS, O2, and short term fuel trim ( int) parameters would be helpful.
Old Jan 25, 2019 | 02:47 PM
Vetteboy31's Avatar
Vetteboy31
8th Gear
No codes when MAF is hooked up
Old Jan 25, 2019 | 02:56 PM
Vetteboy31's Avatar
Vetteboy31
8th Gear
The MAF relay is new, Had no effect on driveability when replaced. The MAF itself is a rebuilt old school one The new versions simply would not work at all. Tried to make several work to no avail. So went and had this one rebuilt When installed error code went away and car started right up. That was when this issue came up
Old Jan 25, 2019 | 04:45 PM
KyleF's Avatar
KyleF
You need a known good MAF. Rebuilt doesn't mean it's right.
Old Jan 25, 2019 | 05:00 PM
vette196's Avatar
vette196
I read a thread on here recently where the guy went through, I believe, 5 "new" MAFs ....mfg process has gone down the ******* with parts
Old Jan 25, 2019 | 07:51 PM
KyleF's Avatar
KyleF
I have been down this road, not with 5 but 2 plus the one on the car. I ended up having to get a remaned unit from online that was the old heated wire style. Bonus, no code 36.
This was why I said a "known" good one. Preferably off a friend's healthy running car. A scan tool would be preferred. See the readings between the different MAFs you have. If they are both the same readings at the ECM but out of spec, my guess would be in the wiring.
To Car dies
