'89 Vette parking brake issue.
Old Feb 10, 2019 | 12:50 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default '89 Vette parking brake issue.
My "new" '89, 6-speed vert has developed an inoperative parking brake, i.e. the brake is "set" and will not release.
I just started using the parking brake because it's a 6-speed manual and think I have pulled the handle up too hard and far. When I pull it up and try to engage with the plunger on the handle end it will not engage the brake mechanism.
I don't yet have an '89 FSM and my '88 FSM parking brake illustrations do not look like the actual '89 brake mechanism.
I have already tried depressing the brake pedal with engine running but still can't engage the unit to release it.
Is there a good procedure to get the parking brake to engage and release?
Old Feb 10, 2019 | 09:14 AM
bosshog8's Avatar
bosshog8
If you have pulled it up too tight then your in a pickle. You can try to hercules it further (use 2 people) to get the pawl to release with the button but you might have to get under there and look for somewhere to make up slack so you can release it. Or possibly take it apart at the handle/self adjuster which is probably what I would do.
Old Feb 10, 2019 | 10:40 AM
BillDurant's Avatar
BillDurant
I have the same issue we muscled it to release. I never use it any more
Old Feb 10, 2019 | 01:47 PM
65Z01's Avatar
65Z01
Damn...thanks.
Old Feb 10, 2019 | 02:52 PM
65Z01's Avatar
65Z01
OK, after probing the PB mechanism here/there with a large screwdriver there was a sudden metallic "pop" and the car began to roll slowly backward.
Don't know exactly what got "triggered" but working fine now. Reconnected the electrical plug, so the dash will remind me to release the brake, and just slid the cover over the PB assembly...for now.
I'm finding that "driving stick" again is a little more than just getting back clutch & RPM "feel"...
Old Feb 19, 2019 | 09:58 PM
02skywalker27's Avatar
02skywalker27
1st Gear
I had the same problem one time after school. The way I unlocked it was to see where the plunger actually hits the brake mechanism and I used a screwdriver to release it. I also noticed that the actual rod that hits the parking brake mechanism was bent outward from it making it extremely difficult to disengage. Maybe check that for yourself?
Old Feb 19, 2019 | 10:03 PM
bud40oz's Avatar
bud40oz
i may be in the wrong here but... usually when the e brake sticks like that it means the cables are rusted/ clogged up with gunk or whatever... again. i may be wrong i know little about corvettes, but i do know about cars in general. especially common on an automatic car where the park brake is never really used.
To '89 Vette parking brake issue.
