1995 lt1, harmonic balancer wobbling off.
I found something online that said 3/8 24 fine? Is 24 the length? What unit is it? Then a mention on the center being a 9/16 "tight" thread. Does that mean fine thread? And what length should I get? Washers needed for it? Ect..
So I'd like to know the sizes of the 3 bolts that mount the harmonic balancer to the engine, the size of the center bolt I need to hold the crank in place to torque. If I need any washers. If I need to apply loctyte, if so which color. Lastly, do I neeeeeddd to remove the water pump to tighten it back down, or can I comfortably work around it?
She's slowly coming around, its been a bigger project than I hoped, my bikes haven't been getting any love. Of course I decided to make things worse for myself by losing my only ignition key. Ouch. Waiting the mechanical key from the dealer so I can bypass the ignition and find out whichs vats key it is. Ill be sure to cut two keys once I revert the system back!
the balancer just attaches to the hub (the hub attaches to the crank) on a LT1. if you put the car on ramps you probably can get to it. if you loosen the belt to take tension off the balancer, you can probably take that bolt out and get matches for it, of course the balancer/pulley is going to be loose but there is only 1 way it can go back together because of the bolt pattern (if I remember correctly)
make some witness marks with chalk if you can
I have not taken mine off yet, so hopefully one of the folks that have can give some better advice
Blue loctite. Not red ! Red is permanent. It can be removed with heat, but you don't want to have to do that. Blue loctite will break loose with just a wrench.
1. Balancer HUB not keyed although crank is - now is the time to replace with a keyed hub.
2. Not fixing properly might damage your crankshaft !!!
3. Balancer so old should be replaced no matter what !
4. ATI SuperDamper good choice.
For the average daily driver, simply replacing or rebuilding the oem one (there are companies that will remove and replace the rubber) is all that is needed. As rubber ages and gets hard (just like in a suspension) it loses its dampening/vibration absorption qualities and simply becomes a spinning mass. I bet a lot of folks experiencing a mild vibration of the engine would find out that if they simply replaced the balancer, the engine would be showroom smooth (or closer to it) again.
With a bit of research, there is no reason the OP can't deal with it unless for one reason or another the OP doesn't work on cars or have the tools, capacities to do it. For an LT1 it is simply a bolt on, you can't get it wrong due to the bolt pattern. Replacing the hub is one thing, simply replacing the balancer another as long as the replacement is correct for the car.
As far as the ATI balancer, for a "built" engine it is probably a good idea, but I bet there are lots of folks running built engines with oem grade balancers due to the balancing nature of the LTx based engines.
I know I will be purchasing an upgraded balancer, in fact, besides injectors, seals and gaskets, that is all I have left to purchase unless I go the stroker cam route, which changes the picture.
Eventually I'll build this engine up some more. It has some work done, but id like to pump it up. Youd recommend upgrading the balancer then eh? Do I need to upgrade the part it attaches to? I was gonna save it till I was ready to do the cam chain swap later this year. Would it be better to wait till then I swap the balancer and just remount the current one?
If that is harsh, I don't mean it to be. It is a reality check. Thread designations such as 1/4-20 3/8-24 is common shop lingo as much as asking for a 1/2" socket.
Do your homework here... the balancer protects the bottom end.
https://www.corvetteforum.com/forums...r-lt1-lt4.html
An LT1 has a hub held by one bolt and it is NOT keyed so if it is removed you must mark it and the engine to ensure it is reinstalled in the same position. The balancer/pulley is one unit and it is held by 3 bolts.
I haven't seen it mentioned but if you have 2 bolts missing from the balancer. you need to verify the threaded holes in the hub are not damaged.
My contribution is this, a man who can't go to the hardware store and as for a bolt/screw/nut by size is about to start screwing with something he may not realize is a critical component of his engine. Saying do your homework means just that. To be honest, you didn't need this thread anyway. This has been covered and to re-type the same stuff again is pointless. Just use the search feature. You would probably find all you need.
Here is a contribution to help you with your fasteners:
The1/4-20 designated the thread outer diameter (.25") and the threads per inch in SAE sized fasteners. 20 threads in an inch means it takes 20 revolutions of the fastener to travel 1in, or 1 turn is 1/20th of an inch. Unfortunately, SAE fasteners basically require a Tap/Drill chart fro the various sizes if you are creating a new hole, or "drilling" something out and re-tapping a new hole.
In metric a M6X1.0 gives you the outer diameter (6mm in this case) and pitch of the threads . Meaning in, 1 turn will move the fastener 1mm. For metric fasteners, using a normal cut tap, drill the hole by the diameter minus the pitch. No tap/drill chart needed. A M6X1.0 tap would use a 5.0mm hole. M8X1.25 would use a 6.75mm drill. And so on.
I am thankful for the enlightenment on how the bolt patterns were developed though, it made a lot of sense.
