D36 to D44 in a 94 A4
Old Nov 1, 2002 | 11:27 AM
Eric94's Avatar
Eric94
Default D36 to D44 in a 94 A4
I'm thinking of doing the D44 instead of rebuilding the D36 with the 3.54 gears. My D36 needs new wheel bearings, and with the cost of the gears thrown in, I figure I may be able to get a D44 with the stock 3.42 gears for roughly about the same(or higher).
I know some of y'all have done this, so here are my questions: What driveshaft do I use? And of course, where's the best/cheapest place to order a used D44 from?
Thanks for the help!
:seeya
Old Nov 1, 2002 | 11:37 AM
Vic'89's Avatar
Vic'89
Default Re: D36 to D44 in a 94 A4 (Eric94)
Please see my post.
Vic
Old Nov 1, 2002 | 11:55 AM
J Z06's Avatar
J Z06
Default : D36 to D44 in a 94 A4
In case He hasn't seen it:
http://forums.corvetteforum.com/zerothread?id=424300
Old Nov 1, 2002 | 12:21 PM
Caboboy's Avatar
Caboboy
Great decision! :cheers:
Edit: Oh cool, 500 posts!!
[Modified by Caboboy, 8:22 AM 11/1/2002]
Old Nov 1, 2002 | 02:28 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: D36 to D44 in a 94 A4 (Caboboy)
Old Nov 1, 2002 | 05:42 PM
93 ragtop's Avatar
93 ragtop
Eric, when I was shopping about a year and a half ago, Contempory Corvette was getting $1400.00 for the parts to convert. This was with a 3.45 gear.
Old Nov 1, 2002 | 09:42 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Eric, give Ron a call at Contemporary Corvette 1-800-367-8388, he gets Dana 44's in and they go out just as fast, they are a hot item. His price is $1400 for the carrier, the cover, the driveshaft and the driveline support.
I got one from him back in May, 40,000 miles from a '94 six speed.
After shopping around, you'll find that $1400 isn't that bad of a price.
Old Nov 3, 2002 | 07:33 AM
Eric94's Avatar
Eric94
JD, thanks for the link, it helped. Mr. Mojo, thanks for the info, I will call.
I have another question now...do you get the 6 speed drive shaft, and how/what do you do to it to use it with the 4L60E?
Thanks again. :seeya
Old Nov 3, 2002 | 07:59 AM
Mr Mojo's Avatar
Mr Mojo
Yes, you get the 6 speed driveshaft, but you'll have to change the yoke, or at least I did, but mine's a '93.
To D36 to D44 in a 94 A4
