Driveline question
Old Feb 18, 2019 | 07:34 PM
vtdave577's Avatar
vtdave577
Default Driveline question
I have a question about the driveline on C4 Vettes and my 87 coupe in particular. I'm wondering just how fragile the rear ends and transmissions are. Mine is a stock (for now) L98 350, with a 4+3 DN tranny and a D44 rearend. I'd like to do some occasional drag racing with it if it will stand up to it. What say you all??
Old Feb 19, 2019 | 01:15 AM
gerardvg's Avatar
gerardvg
No problem stock, when you mod for a lot more h/p you may need to upgrade to a ZF6 speed manual transmission.
Old Feb 19, 2019 | 05:09 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
While I don’t have any more than stock, there are plenty of examples where the stock 4+3 has heaps of hp. The trick as I e read it is not to shift the OS under wot. And clutch shift it.
Old Feb 24, 2019 | 08:07 PM
BLKMAMBA's Avatar
BLKMAMBA
so far my D36 with 2800 stalled auto pulling 1.7 60' has held together
Old Feb 24, 2019 | 08:58 PM
Kevova's Avatar
Kevova
Other than 84, Manuals come with D44 8.5" it will take alot. With street tires most of the time tires will spin preventing breakage.
Old Feb 24, 2019 | 09:04 PM
Benny42's Avatar
Benny42
I have dozens of passes on my '86L about half on the 4+3 and the rest on the T56. All of them on the D44. I agree with the above, the 4 speed
section of the 4+3 is pretty darn tough. You won't be using the OD at the drag strip so you should be good. Go have some fun.
To Driveline question
