1990 Corvette Vacuum Control Valve HELP!!!
I have bought my dream car a 1990 red Corvette, that I call Brenda. I took her to the shop to get serviced and to replace the valve cover gasket. I got her back from the shop and after a day or so, I realize that the AC is blowing from the defrost and the leg vent. I do some research on these forums and rather than taking Brenda back to the shop which is far and inconvenient, I buy a vacuum control valve and some tubing. I pop the hood look around and low and behold the tubing that goes to the T to front of the car is against the exhaust manifold and it's melted open. I replace the tubing. (AND THIS IS WHERE I SHOULD OF STOPPED) But I bought the 4 dollar vacuum control valve and I thought, "might as well replace while I am here." Big mistake, I remove the the other hoses and the tubing breaks off. Now it's like the big tubing disappeared. I can't find it anywhere under the distributor. I spent over an hour looking for it.
See if I am right here. Now, I know enough about cars to get me into trouble. #3 goes to the front of the car to a T. #2 goes to the passenger side of the engine to an assembly. Where does #1 go to? I don't know where to look for it in the service manual. I tried HVAC, Vacuum lines, the internet, these forums. Nothing. Can you help me get Brenda back on track?
Thanks so much.
Alex
Thanks so much.
Alex
is your plan to splice some 5/32 id rubber line over the broken stubs of the hard line? and you cannot find one side that dissspeared back at the distributor?
i put a dob of contact cement to ensure a permanent splice.
