96 LT4 sway bar sizes?
If you don't have a dial caliper go to Harbor Freight, buy one, source a 20% off coupon first. Once you have one, there will be other uses for it. Just remember, they are under $20.00, they aren't clamps or made to be abused. The first thing I was taught in machinist school was micrometers are not c-clamps. You can hurt a dial caliper by being too heavy handed.
Or borrow one.
The different sway bar sizes are enough different that a .001 or .002 won't make a difference
https://www.harborfreight.com/6-in-d...per-63730.html
then measure the bar size. to get to metric multiple the measurement * 25.4 conversely to get from metric to decimal multiply the figure by .03937
so 13 mm = 13 * .03938 = .51181 that is why a 13 mm socket will fit on a bolt with 1/2" head
conversely .51181 * 25.4 = 12.99997 round it to 13 mm
Here is the chart of sizes if you just want to assume it is stock
https://www.corvetteactioncenter.com...usp_chart.html
