4L60E interchange...case decoding
Old Mar 1, 2019 | 05:56 PM
dhirocz's Avatar
dhirocz
Default 4L60E interchange...case decoding
I have a 95 with a blown 3-4 clutch pack. I want to remove the trans and send it off and have it built, and while I still am, I realized I have another 1995 2wd transmission sitting around I forgot about.
Code is 5TBD112H on the oil pan rail. Its a K case with the ears cut off. The service sticker is gone. Havent found anything on Google, im probably not using the right search terms.
Im thinking it would work temporarily in my 95 until I get my transmission back, but Im looking to confirm it will work. I know 95 is sort of a weird, one year only deal. Can anyone confirm this?
Old Mar 1, 2019 | 06:28 PM
WVZR-1's Avatar
WVZR-1
Take the code to a GM dealer and I'd think you'll likely find it to be maybe a 4.3 '95 Blazer/Jimmy 2WD
I was able to stumble upon this application for a SERTA for that transmission code. I would doubt it able to be used as an 'interim' for your car.
Old Mar 1, 2019 | 07:53 PM
383vett's Avatar
383vett
I thought the 93s were the odd year tranny cars with the 4l60 without the E. It was more of a 700r4.
Old Mar 1, 2019 | 08:26 PM
dhirocz's Avatar
dhirocz
Apparently,you can only use a 95 in a 95...
Old Mar 1, 2019 | 08:49 PM
JackDidley's Avatar
JackDidley
Try this.
Old Mar 1, 2019 | 10:02 PM
dhirocz's Avatar
dhirocz
...keeps giving me errors. Do you happen to have a link?
Old Mar 2, 2019 | 09:53 AM
JackDidley's Avatar
JackDidley
I think I fixed it.
To 4L60E interchange...case decoding
