Dm flywheel balance mark missing
Old Mar 7, 2019 | 08:12 PM
1990CONV's Avatar
1990CONV
Default Dm flywheel balance mark missing
I am installing a NOS clutch assembly in my 1990 L98. The DM flywheel, pressure plate and disk are new from the 90's. I noticed the pressure plate has a yellow paint dot by one of the mounting holes. I can see nothing on the flywheel. I have had the flywheel for twenty years in a box in the attic and have taken it out several times to clean and wipe it down so that it did not rust. Perhaps I wiped the mark off. The old DM flywheel did have a green dot on it. I did install a new balance pin weight on the new one that matched the old one's position. Do the the paint dots really matter? Since the one on the flywheel was either never there or I wiped it off should I be concerned and what are my options?
Old Mar 7, 2019 | 10:01 PM
LPDesRoche's Avatar
LPDesRoche
It won't matter. Just install and break it in like normal.
Leeland
