Knock sensor removal
Old Mar 20, 2019 | 02:27 AM
AudioObsessions's Avatar
AudioObsessions
Default Knock sensor removal
Ugh, I have tried for over an hour. I tried a wrench which was a pain to get in there and I even tried a socket and it won't budge. Any tips?
Old Mar 20, 2019 | 10:16 AM
anesthes's Avatar
anesthes
If the 7/8" socket just spins than the best bet is to use a pipe wrench.
-- Joe
Old Mar 20, 2019 | 02:55 PM
DGXR's Avatar
DGXR
If it really is that stuck, you can (carefully) try it with a hot engine, that may help. Or try some penetrating lube. That should not be necessary though, since the body screwing into the block is made of brass and the torque is only 14-15 lb-ft. If those don't work, you may have to destroy it in order to remove it. Just keep twisting on it until something gives. Try a pipe wrench or long channel-lock pliers.
If the end is just spinning (as anesthes stated) then it's already destroyed. Fortunately, new ones are not very expensive. Good luck.
Old Mar 22, 2019 | 01:10 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Spray some PB Blaster onto the area, let stand overnight, warm up engine and give it a try.
To Knock sensor removal
