Performance Distributor
Old Nov 3, 2002 | 04:51 PM
Ezgoin721's Avatar
Ezgoin721
Default Performance Distributor
I set out to simply replace my ignition module this morning and decided to replace the entire distributor in stead. All the connectors and gromets were hard and brittle, and the shaft it's self seemed to have a lot of play.
Who here runs an after market distributor? What kind? Where did you buy it? How much did you pay?
:cheers:
Old Nov 3, 2002 | 04:57 PM
Corvette0096's Avatar
Corvette0096
Default Re: Performance Distributor (Ezgoin721)
I bought mine from a forum member. Accel blue print with the MSD cap and rotor with the hot coil for like $150 in the box. Mine was in bad shape like the way yours sounds..
Old Nov 3, 2002 | 05:07 PM
J Z06's Avatar
J Z06
Mine has 108K on it. The module was toast not too long ago along with the pickup. I'm going to be running a different distributor when the new computer goes in. I basically have a re-built distributor.
[Modified by JD 90 383, 4:07 PM 11/3/2002]
Old Nov 3, 2002 | 08:39 PM
HWoods's Avatar
HWoods
Default Re: Performance Distributor (JD 90 383)
I went with the small cap hei conversion in my 86. I use an MSD unit. It is pretty easy to do or the guys at http://www.performancedistributor.com make one, Accel rebuilds the stock dist.
Old Nov 9, 2002 | 12:38 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Do you feel it is better to buy new....than to upgrade???
thanks
tony
:cool:
Old Nov 9, 2002 | 08:34 AM
Millican's Avatar
Millican
Default Re: Performance Distributor (oldace84)
Stay away from the Accel replacement distributor. The electical parts are of low quality. I had one and 6 months later the ignition module failed. It almost left me stranded.
To Performance Distributor
