Transmission filter change
**I believe there's 'stop' on the valve body that the stick hits on most 4L60E because of various installs including maybe the early 'other than C4' applications.
GM # 8684890 I'm quite sure is used in the C4 -4L60E
You did use a 'genuine' GM/ACD filter?
Did anyone else notice that the end of the tube aligns perfectly with the COLD/FULL level on the dipstick? So if overfilled, suck on the tube itself and flow will cease when the level reaches the bottom of the tube and it sucks air.
EDIT II: I have a better thought: It is to prevent service personnel "flush equipment" from being inserted into the tube and knocking the filter/pickup out of the pump snout. Because the pan isn't removed during a "flush", a dislodged filter wouldn't be detected until the trans was burned up. Dan: take a look after the filter is installed. I'm pretty sure the forward corner of the filter is under the filler pipe. You should evaluate whether removing the stop, or even your tapered 1/4" tube will get to the bottom with the filter installed.
Cheers
ihatebarkingdogs-I think with a 1/4" clear tube with a 45 deg cut on the end would be impossible to put any force on the filter. I just spin it around until the 45 deg cut is in the right place and it slides right down without any force whatsoever.
Turtle96-- I received the new bolts and as you said they are different. The washer is like WAY more cupped than my 23 year old ones. Maybe the FSM knows something after all. I can't comment if they torque any different as I have never tried to torque any 23 year old ones.
Thanks again for all your help!! Dan
Thread has been quite informative for '94+ 4L60e owners. This snapshot maybe more so. I and no one else ever commented about the fluid! You mentioned I believe flushed last year and the fluid I'd say was certainly 'pretty'. I had meant to mention this much earlier in your thread. New hardware is certainly a positive experience from time to time. Trans service seems to one of those. The newer hardware I do believe is different from OE original production. Engineering experience by GM/OE. Did RA supply ACD product?
You can't knock the filter loose with the dipstick. You probably can't rotate the solenoid enough to interfere with it either, because the harness isn't long enough. (Although that would be a good reason for its existence.) The TC solenoid wires aren't long enough to tangle in it either.
It seems to show up on the later units here, with cupped ends on the tube.
Maybe they were concerned the cup would catch on something, like the edge of the VB and bend or break it? Maybe they don't want you "splashing" the fat, rounded, end in the pan upon insertion and giving a false reading?
We never buy new bolts here, and torque them to about 110 in lbs. If you have to really lay into a pan bolt to get it to seal, the pan probably has a damaged rail. No retorque is required on the farpack gaskets, or the rubber aftermarket ones. (Which seem to hold up pretty well.
Cork will compress, and you snug them in a month or so and they're good after that.
