Vibration at certain RPMs...
Old Nov 3, 2002 | 09:41 PM
amswak's Avatar
amswak
Default Vibration at certain RPMs...
I have a little vibration at certain RPMs when I rev the engine. I have hear the L98s were a little rough due to how the cams were. It doesnt feel like anything is going to go on it, but if something is out of balance (like maybe the flywheel?) I would like to fix it....Anyone have any thoughts on what it could be?
[Modified by amswak, 1:45 AM 11/4/2002]
Old Nov 3, 2002 | 09:51 PM
Corvette0096's Avatar
Corvette0096
Default Re: Vibration at certain RPMs... (amswak)
I would check the harmonic balancer. Mine was so bad it spun and almost ate a whole in my timing cover..
Old Nov 3, 2002 | 10:10 PM
amswak's Avatar
amswak
would that cause some noise to sometimes? like through a parking lot? How do I check it, how do i fix it, and how much $? Thank you!
Old Nov 3, 2002 | 10:14 PM
Corvette0096
The first thing I would do is see if it has spun. Check the timming with a light and give it a good look..Yes they will make noise if they are rubbing on something. As for the cost I spent $200 on my balancer. But that is with my new motor. You should be able to get one from GM for around $50
To Vibration at certain RPMs...
