"SYS"
My oil change lite is on. Any possible connection? I plan on changing the oil in the next couple days.
please help.
vr,
Volt
does the cold do that to the battery?
In the owners manual it says "SYS" is an electrical problem....battery makes sense.
If the "SYS" is flashing it means the code is currently happening. If its a steady, its a history or it happened recently.
You can pull the codes with a paper clip under the dash. I don't have the contacts memorized, but they are pretty easy.
People most often have SYS when the battery starts to fail. The CCM monitors a wide number of non-engine systems and if it sees voltage drop below 9v, it will throw a code. Typcially, a low battery will start the engine but drop below 9 v for a moment, thus tripping a code. If you pull the codes, you will see, for example the radio, when it has nothing to do with the radio. However, you can get the SYS message and its not the battery. So don't think can only be the battery.
With a weak battery, when you start the engine, the current draw by the starter may be high enough to cause other systems to see less than 9v for just a moment and set the code resulting in the "SYS" message from the CCM.
[Modified by Mez, 6:00 PM 11/4/2002]
1. Buy (2) 1 kilo-ohm 1/2 Watt resistors. [Radio Shack part # 271-023. They sell them as a 2-pack for 29 cents.]
2. Disconnect the negative battery cable.
3. Remove the receiver.
4. Connect one end of both resistors to ignition power. (Yellow wire in the car.)
5. Connect the other end of one resistor to the purple/white wire in the car.
6. Connect the other end of the second resistor to the grey/black wire in the car.
7. Cover all connections and completely cover the resistors.
8. Reconnect the negative battery cable.
I have yet to do this myself, but it should work... :D
