Someone on here must still have the converted LT4 tune for the OBD1 PCM. I put a LT4 in my 1996 Camaro SS. Desperate need of the OBD1 tune file that was made some 16 years ago.
From: Las Vegas - Just stop perpetuating myths please.
I think you need to sort a few things out jer. A '96 car would use a OBD II tune. 95 was OBD 1.5 and by 96 they were all OBD II. And I don't think a corvette tune will work in an f-body.
If you can upload your tune and download a new tune then you can look at and modify tables with your software (TunerCat?). Finding a similar tune to look at and copy shouldn't be to difficult. Have tried Gearhead EFI?
Reason: correct OBD I to OBD II
To add to the last post, a 1996 should be obd2, and anything before that is obd1. With that said what computer system is in your 1996? The stock obd2 or did you put an obd1 computer in the car? If you have a obd1 or obd2 computer then a hot camed camaro tune would be close enough to start with, just get the correct operating system.
I'm converting my car to obd1. Using a 1995 Camaro pcm. I think I may actually have the tune already. I thought it was the obd2 factory tune. But it seems to open and change in tuner pro.
