Max tire size for an 85?
Old Nov 4, 2002 | 12:54 PM
steveelsbury's Avatar
steveelsbury
Default Max tire size for an 85?
Got 275's on the rear at the moment and still having traction problems.
Question 1: Will 315's fit with the right offset without extending beyond the wheel arch (my existing 275's clear the inner wheel well by about 1mm!
Question 2: How large a wheel arch extension will I need for 335's?
TIA
Steve
Old Nov 4, 2002 | 01:01 PM
LD85's Avatar
LD85
Default Re: Max tire size for an 85? (steveelsbury)
I have 315's on the rear with the correct offset. The Grand Sport extension flare works great but I have yet to buy them
[Modified by ld85, 12:02 PM 11/4/2002]
Old Nov 4, 2002 | 07:30 PM
VetteRacer282's Avatar
VetteRacer282
If you run ZR1 (with ZR1 offset) in the rear you will be fine. You can squeeze a 335 on there if you needed, but 315 fits better.
No flares needed!
Matt
Old Nov 4, 2002 | 07:36 PM
steveelsbury
Default Re: Max tire size for an 85? (VetteRacer282)
What does 'run Zr1' mean? Is that a type of wheel? I am currently using 18x10 inch rims.
Steve
Old Nov 4, 2002 | 10:37 PM
jmrl98's Avatar
jmrl98
Michelin 315x17x40's on mine. Too much meat, it's slowin' me down! :(
Old Nov 4, 2002 | 11:15 PM
Bill Reid's Avatar
Bill Reid
Steve,
With a 36.5mm offset (ZR-1) you will be able to fit a 315/35R-17 more or less flush with a 17X11" rim. 335's are pushing the limit, really. You can see by this shot that they fit well with a 1/2 degree of negative camber:
[Modified by billreid1@***.net, 8:16 PM 11/4/2002]
Old Nov 5, 2002 | 02:54 AM
vettl83's Avatar
vettl83
Default Re: Max tire size for an 85? (billreid1@***.net)
Steve,
Bill I have a set of ZR-1 wheels and tires off my 91 ZR-1. Are you saying they will bolt up to the 84's and 85's without the use of adapters? 84 CF 91 ZR-1
Old Nov 5, 2002 | 03:21 AM
C4Dreams's Avatar
C4Dreams
Default Re: Max tire size for an 85? (vettl83)
ON stock 85 wheels, how wide can u go? Btw will 89 WHeels fit on my 85 with no modification..?
C4Dreams
Old Nov 5, 2002 | 06:46 AM
steveelsbury
Default Re: Max tire size for an 85? (jmrl98)
Surely not! I thought more traction could only be a good thing?
Old Nov 5, 2002 | 06:49 AM
steveelsbury
Steve,
Thanks for the feedback everyone. My decision now is to either fit the 315's, or wait until I do the bodykit and go 335......any drawbacks to the larger size?
Steve
Old Nov 5, 2002 | 06:12 PM
jmrl98's Avatar
jmrl98
I've been wondering about this thought. Bigger tires, more surface area, more traction. Yet what about the moment of inertia of the tire? It takes more energy to move them big ole' meats as opposed to a smaller tire. The question becomes how negligible is the moment of inertia as compared to traction gain? This is probably one of the reasons true slicks compress somewhat off the launch - it eases the moment of inertia of the tire. I have the stock rims in the garage, and I need tires anyway. In spring I'll try track comparisons and see if there is a noticeable difference. They will be different make tires though, so that has to be considered, along with difference in size of the tires. :seeya
Old Nov 5, 2002 | 07:19 PM
JoBy's Avatar
JoBy
You need adapters for the front but not for the rear.
http://w1.601.telia.com/~u60113743/corvette_wheels/
Old Jul 7, 2019 | 11:28 AM
Allen Anderson's Avatar
Allen Anderson
1st Gear
Anyone know if 285/35/19 will fit on 1985 corvette?
Old Jul 8, 2019 | 12:13 AM
MatthewMiller's Avatar
MatthewMiller
It's about an inch too tall. You can fit it with the proper width/offset wheel, but it will look a little strange and raise the CG and roll center. So...not ideal.
To Max tire size for an 85?
