85’ vacuum hoses
Old 04-15-2019, 09:42 PM
Mason123
Mason123's Avatar
Default 85’ vacuum hoses
My 85 in idle will show RPM’s all over the place. It’s not steady. Sometimes the car will stall and die.
my vacuum hoses are messed up. Can that cause the issue and how can I go about fixing it?
also, what’s that circle looking thing above the battery. Drum looking thing?
Old 04-15-2019, 11:00 PM
VikingTrad3r
Oil Producer
Support Corvetteforum!
VikingTrad3r's Avatar
Received 2,262 Likes on 1,446 Posts
its the cruise control controller.
there was a guy here a few weeks ago eith vac lines from an 85 in a thread. did u search forum? should be able to find his posts. your vacuum system MUST be up to spec especially on the 85. it doesnt handle compensation as well as 86 and later.
repair vac lines
do minimum idle procedure
report back
Old 04-16-2019, 02:42 PM
Mason123
Mason123's Avatar
repair vac lines
report back
i tried to find out how to fix the vacuum lines but I don’t know how. Any tips ?
Old 04-16-2019, 03:10 PM
confab
confab's Avatar
https://www.corvetteforum.com/forums...post1585483576
Measure them, or just cut pieces as samples, and go to the part store and get some new lines of the same size and replace them.
Old 04-17-2019, 12:47 PM
85vegasvette
85vegasvette's Avatar
I had the same issue when changing my injectors the plastic shattered, and the diagrams help alot, i have an 85 also , now i never had the check valve off of the plenum in the back, i ran it to the vacum tank, my idle is almost solid, and i have cruise,as and heat so sometimes it just works without knowing why
Old 04-17-2019, 10:27 PM
Mason123
Mason123's Avatar
think you can give me a bit of assistance? I don’t understand the diagram much and I’m confused exactly where these vacuum hoses go and stuff. Thanks!
To 85’ vacuum hoses
Quick Reply: 85’ vacuum hoses
