Overheating?
Old Apr 24, 2019 | 01:05 AM
Cos1's Avatar
Cos1
1st Gear
Default Overheating?
Hello everyone! A couple weeks ago I bought my first Vette ( childhood dream). It’s an 86 with an automatic. It was an hour an a half drive to get it home. Car ran around 186 degrees until the last five minutes of the journey when it steadily went up to 220 by the time I pulled in my driveway. According to previous owner the car sat for a year or so in his barn so I bought it expecting to put some money into it. I did not keep car running to see how hot it would get but thought it was odd the temp stayed steady in the mid 180s for over an hour before rising 40 degrees in the last five minutes of driving. Coolant was a little low so I topped off. Am I over thinking this or could a problem be occurring? Any thoughts?
Old Apr 24, 2019 | 08:07 AM
Whaleman's Avatar
Whaleman
Use the search. Go to advanced search. Type in "overheating" in the search terms in "titles". Click on search C4 only. You will have a weeks reading when the search comes up.
Old Apr 24, 2019 | 08:22 AM
pacoW's Avatar
pacoW
Pay attention to when the cooling fan kicks on and off. Watch the temp gauge when this is happening, you will have your answer.
Old Apr 24, 2019 | 08:24 AM
81c3's Avatar
81c3
What you describe sounds fairly normal. I imagine the last 5 minutes of your journey was in town more so than interstate....So that would make sense that with less air flow the temps would rise. Fans come on around 225 degrees. Drive it again, then let it sit... if the fans come on like they should, the temp will drop and the cycle will start over. Make sure there are no obstructions in the open area under the car in front of the radiator. Many times theres will be trash and dirt found between the condenser and the radiator. Probably couldnt hurt to do a proper coolant flush and refill if you dont know when the last time it was done. 50/50 mix using distilled water.
Old Apr 24, 2019 | 11:51 AM
c4cruiser's Avatar
c4cruiser
Also check the air dams under the front of the car. These pieces work to divert cool air into the opening in front of the A/C condenser and radiator. Look for any sort of damage of if they are loose. Replace as necessary.
To Overheating?
