1996 Corvette Cruise control
Old Apr 24, 2019 | 11:28 AM
drifter5674's Avatar
drifter5674
Default 1996 Corvette Cruise control
Will cruise control work with ABS and ASR light on? Cruse doesn't work. Checked vacuum. It has vacuum at diaphragm.
ABS light and ASR go off when car is started but come as soon as you touch the throttle. Changed TPS sensor. No Change
Old Apr 24, 2019 | 04:24 PM
don hall's Avatar
don hall
Have you checked the fluid level. Your '95 is very sensitive to having a full reservoir.
Don't know if ABS light affects cruise control.
