Coolant Temp sensor ??????????
Old Nov 4, 2002 | 08:38 PM
blkc6z51's Avatar
blkc6z51
Default Coolant Temp sensor ??????????
Would like to know if the coolant temp sensor is also the
fan switch, is it one in the same. The gauge is not working so how can I test the coolant sensor. Thanks
Richard. Car is 90 stock.
Old Nov 4, 2002 | 09:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Coolant Temp sensor ?????????? (blk90)
They are separate sensors.
I believe the coolant temp sensor is in the front of the intake manifold.
Old Nov 4, 2002 | 11:40 PM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Default Re: Coolant Temp sensor ?????????? (65Z01)
The sensor in front of the engine sends coolant temp to the ECM. The guage reads coolant temp from a sensor on the right side engine block between spark plugs 6 and 8.
Old Nov 4, 2002 | 11:59 PM
blkc6z51's Avatar
blkc6z51
Thanks guys
found it I must have knocked the wire off when installing plugs :rolleyes:
Richard
Old Nov 9, 2002 | 06:36 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Replace the fan switch...should be in the pass. side head.......start at 180*
off at 160* with a 160 thermostat....works for me.....should be the same for you....whatever????????
:D :D
Old Nov 9, 2002 | 06:37 AM
oldace84's Avatar
oldace84
Get new fan switch from mid america...zip or ecklers......take your pick....all will do the same....
:yesnod:
To Coolant Temp sensor ??????????
