Dewitts single row
Old Apr 26, 2019 | 06:51 PM
helives4u2's Avatar
helives4u2
Default Dewitts single row
Hello, can anyone tell me how important the foam that comes with the radiator is? Looks like it would make it more of a pain to put the shroud back on. The reason I'm asking is I already installed it without it and the two plastic strips that were in the box. Everything lined up good. There were new bolts too I didn't use. Will it be okay? Thanks Mike
Old Apr 26, 2019 | 10:10 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
The plastic strips are to mount the fans back. The foam block some air from going around the radiator.
Old Apr 26, 2019 | 10:24 PM
helives4u2's Avatar
helives4u2
I didn't use the plastic strips to bolt the fans back up they seemed to go back on pretty easy, that should be okay right? Do you think it will make a difference if I don't use the foam? I can pull it back out if needs be.
Old Apr 26, 2019 | 10:44 PM
helives4u2's Avatar
helives4u2
Old Apr 26, 2019 | 11:55 PM
helives4u2's Avatar
helives4u2
I think I'll pull it back out and put the foam on it. Might as well do it right. Thanks for the information
Old Apr 27, 2019 | 06:22 AM
helives4u2's Avatar
helives4u2
Okay, done right this time, I'll never attempt to do any project on my car before work, man was that sloppy! Installed the Trans cooler too.
Old Apr 28, 2019 | 06:39 PM
helives4u2's Avatar
helives4u2
Well, between the Dewitt's and B&M cooler the trans temp is down 38 degrees. It was getting to 212 @ 70 outside temp, today its 95 outside and it reached 174.
Old Apr 28, 2019 | 08:50 PM
84 4+3's Avatar
84 4+3
I'd attribute that to the trans cooler. Still good results though!
Old Apr 28, 2019 | 09:43 PM
helives4u2's Avatar
helives4u2
Im thinking 70/30, the radiator has a 1" copper tube for the Trans fluid, plus the tank is aluminum.
Old Apr 28, 2019 | 11:08 PM
84 4+3's Avatar
84 4+3
Fair. More surface area should keep the trans fluid closer to coolant temps too rather than higher. I did drop almost 50 degrees towing with my truck just by adding a B&M plate cooler though. The radiator in that thing makes the stock C4 one look good.
The single row doesn't need the condenser upgrade either, does it?
Old Apr 28, 2019 | 11:33 PM
helives4u2's Avatar
helives4u2
No, the only thing you have to do is cut the rubber mount on the drivers side a 1/4" or so. The stock radiator looks anemic compared to the Dewitts
To Dewitts single row
