I ran a search on this, but found nothing.
Im trying to find out if there’s a glue that will work to join two sections of the airbox.
I have an early tip airbox from my ‘89 that fits the car, but I want to use the manifold end from a late airbox.
Its not feasible to use the late box on an early car as the angles are different and the late box air filter end is too long to use with the early lower shroud.
suggestions? Thanks in advance for any help.
I've used this to fix some dash parts and other things just using the solvent portion: https://www.plastex.net/Product_Info.php
May or may not work for you but it's worth checking.
Thank you to both of you. Still not sure how I’m gonna do this. I need to really think this thru, because once I start cutting and fitting, there may not be an opportunity for plan B.
