Low Coolant
Old Nov 5, 2002 | 02:03 AM
Juliet's Avatar
Juliet
Default Low Coolant
Overflow tank is topped off to full level. '87 700R4 w/ 123k mi has a new rad / cooling system / hoses and is not running hot. I get the Low COolant light intermittently when it's cold out. Once it gets up to almost 50 degrees outside temp it doesn't come on. This was a problem last spring, but then I didn't see the Low coolant light once all summer (hot weather). Now that it's getting cold again it's giving me the ligh. :( Where is the sensor and what does it take to swap it out? Does it require a full coolant drain (flush would be a good idea anyways). Thanks, ~Juliet
Old Nov 5, 2002 | 03:45 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Low Coolant (Juliet)
That sensor is on the radiator tank,just below the Fill cap a few inches down...youll see a wire(I think its green) coming off the sensor there)
The sensor has two side clips that allow it to stay on the radiator tank but it also has an O ring inside it so it need to "pop" out of there when prying it out.
Very easy to change if defective and you dont need to drain everything out,maybe just let some out halfway.
Btw that sensor seems to throw false codes alot.Wether its an air pocket,its cold out or what have you it loves to light up and scare ya for a few.
Hope this helps.
Old Nov 5, 2002 | 03:50 AM
65Z01's Avatar
65Z01
Assuming you've "burpped" the cooling system to remove any trapped air, you might want to pull the overflow resevoir and inspect both the rubber hose that feeds into it and the plastic tube it attaches to.
The hose can develope a crack that causes the system to lose vacuum and the plastic tube can become clogged. Either condition can prevent the coolant from being drawn into the radiator when the level drops.
Old Nov 5, 2002 | 11:55 AM
Juliet's Avatar
Juliet
Default Re: Low Coolant (65Z01)
Thanks for the feedback. The reservoir and hoses were replaced about 20k miles ago when I had a new radiator put in the car. The system has been burped. I'm thinking that when it gets cold out the resistance changes or something because the sensor is on it's way out and it just hits the threshold it turns the light on. It won't hurt to flush the cooling system. :yesnod:
Anything in particular to watch out for? It will be a month before I can get access to the lift in the garage (Greg's C2 is in engine swap), so I might just take this down to the local service station and have them drain the coolant / put in the sensor / refill (with me hovering around watching of course) :lol: Seems easy enough.... it's due for an oil change anyways....
Old Nov 5, 2002 | 12:01 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Yea seems easy enough but don't let your guard down for one minute. I had an arguement with an oil changer employee about the way he was going to hook up the coolant machine. He was going to put in on backwards! :rolleyes:
Old Nov 5, 2002 | 12:23 PM
Juliet's Avatar
Juliet
Default Re: Low Coolant (War Machine)
Yea seems easy enough but don't let your guard down for one minute. :rolleyes:
:lol: I've got this one mechanic at the local place pretty much trained to deal with me when I take the car in for an oil change or whatever. They know I'm really **** when it comes to my vettes and I do most of the stuff myself. Usually as soon as they raise the lift up I'm under the car with a bottle of simple green & a roll of papertowels anyways. :lol: It's rough though when you have to tell the mechanic that I'll take it to the corvette specialty shop for anything more involved mechanically. :eek: The guy who owns the shop used to be my neighbor and had a red 86 for years, so I pretty much get special treatment :) and they're not total vette neophytes. :cool: But I watch them like a hawk anyways. :D
Old Nov 5, 2002 | 12:40 PM
War Machine
:lol: :lol: :lol: :cheers:
To Low Coolant
