Batwing bushing question
Old May 1, 2019 | 12:42 AM
AudioObsessions's Avatar
AudioObsessions
Default Batwing bushing question
I'm working on replacing the bushings in my rear differential. The old rubber bushing was a pain to get out I had to drill it out. However now that I have it out it seems as though my new poly bushings do not want to fit. It appears like there is a sleeve still in the differential housing. I have included a photo below. To anyone who has replaced these bushings with poly, is this a sleeve that has to come out?
Old May 1, 2019 | 01:01 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yes, that needs to come out. Hit it inward w/a punch to collapse it and it will come right out.
Old May 1, 2019 | 01:36 AM
DMITTZ's Avatar
DMITTZ
Yes, as tom has stated that sleeve needs to be removed.
Old May 1, 2019 | 02:03 AM
AudioObsessions
Ugh, yeah I figured. I have been banging at this thing for an hour now and all it does is twist and bunch up. Would have been easier to just toss a match into the gas tank😂
Old May 1, 2019 | 02:06 AM
DMITTZ's Avatar
DMITTZ
They are a pain to get out. Try carefully using a metal hacksaw blade to cut that sleeve in half then, use the punch to force one half out then the second half will fall out easily.
Using the hacksaw blade is really tedious but in the end cutting the sleeve in half will work.
Best of luck!
Old May 1, 2019 | 08:43 AM
Kevova's Avatar
Kevova
Depends on the hammer. A 48 -64 oz does wonders.
Old May 1, 2019 | 09:15 AM
AudioObsessions
Best of luck!
Cutting it in half with a hacksaw blade did the trick! Thanks for the help everyone.
Old May 3, 2019 | 08:39 PM
xrav22's Avatar
xrav22
Easy way is put a visegrip on the lip and twist works for rear sway bar also.
To Batwing bushing question
