Torque Build 350 Centered Around FIRST TPI
Maybe at the end of the day, it's cheaper to just go ahead and get the bigger block that still allows a FIRST TPI intake. I.E. maybe a 400 or 383. But can't turn down a 427 if I know a way to bolt up a TPI to it.
I agree that too many people get focused on that max hp number rather than power to weight. I think 400to 450 would be the most I'd want.
Many years ago I started a build using my 427 Big Block. The blocks machining was all done and the inside was painted with Glyptal sealing the pores of the Cast iron block. I started looking for a Crankshaft to use in my build and I went through 11 cranks before I found one that would pass the magnaflux testing. These were FORGED crankshafts and the first 10 all had little tiny cracks in them. I bought the best crank I could afford and used a kit from Comp Cams to build my valve-train. The Rods I bought were a new set and even those were magnafluxed to be sure I was okay. I have Forged Pistons on my Forged Rods on my Forged Crankshaft. This bottom end was balanced at 7000 rpm and it works great 26 years later. I am using 12.25-1 Compression with cast Iron GM heads (3931063, 100.3cc's) that use the Closed Chamber design. The closed chambers were chosen for their resistance to detonating even with higher compression. The combination I chose was my idea to make lots of power. It works very well and pushes my little 1968 C3 down the road quickly. The problem is like mentioned before, what good is the power if you can't get it to the ground? My 1968 will spin the tires half way down the quarter mile track if you let it. It looks impressive and sounds awesome but spinning tires are useless, try some good slicks and then your differential, transmission and half shafts will start breaking, ask me how I know?
Just because you have Forged Pistons doesn't mean your car is ready for making more power. If the 140,000 mile bottom end is "weak" you will soon find out after installing the engine. If it were my car I would seriously think about using a 4 bolt main block and build it using quality forged parts.
Build the engine the right way even if it takes more time. Rushing on an engine can lead to a expensive disaster and ruined parts. Take your time and do it right the first time, build the whole engine at once, adding new heads to a old high mileage block sounds like a recipe for disaster, In my humble opinion of course. I spent a year building my 427 the way I wanted it. I have a spare 350 Lt-1 with the double hump heads (Camel-hump) in my garage. I stuck it in my C3 while the 427 was coming together and kept on driving my C3 for the whole year. The LT-1 engine was able to get 21 mpg with my 3.36 rear-end and my Muncie 4 Speed. I had a buddy who had a real live 1970 LT-1 and my poor little 350 outran him every time and he had the 4.11 rear in his car.
Enjoy your Corvette for all it is worth! Build the engine of your dreams just do the entire engine at one time and you will be happier in the long run!
Best Regards,
Chris
Best Regards,
Chris
So in that light, consider the TPI engine. In stock form, it has no more torque off idle than the later, short-runner LT1 did. It has a torque peak around 2500rpm, and that torque then falls off very rapidly as the intake's resonant tuning becomes a barrier to flow above 4000rpm. So all you really have is a peaky engine whose peak just happens to be at low rpm. The bottom line for that build is that it's slow and you still have to row the gears a lot because it's so rpm-limited. OTOH, the LT1 pulls just as hard off idle, doesn't have a brief peak, and pulls to a much higher rpm. It's powerband is way broader and more flexible, and it can make way more power. It's faster and easier to drive fast. With a little better flow and cam, the LT4 was even more so.
So what's the lesson here? The lesson is that a long-runner TPI-based intake is a bad way to spend $1000. No matter how hogged out the runners and base are, it's still going to impose a hard limit on rpm, meaning power is going to be limited. No matter the heads and cam, on a 350 the OP is going to struggle mightily to make an honest 350rwhp (his stated goal). In fact, I'm going to go ahead and say that if he keeps the cam mild for good street manners (another stated goal), the power goal just isn't achievable. OTOH, it's probably well within reach if he uses a short-runner intake like a Miniram. And because he'd be using a fairly mild cam with wide LSA, it would have good manners and be super-flexible in its useful rpm range. If someone has a TPI intake sitting on a shelf and doesn't want to spend money on an intake, then go for it. But to lay out four figures for an intentionally restrictive intake, all in the name of "torque," seems like a very bad idea.
then swap in an LS when it does
the age, tech, design, is ancient in terms of what is available now, and is somewhere around 10x (yes 10 times) as expensive to make about half the power.
And then a ratnest mustang coked out and hooked on a little 350shot maybe??
You're the second person to say that the First intake has shorter runners than a stock TPI (or maybe that was you on FB?). I cannot say one way or the other. I have not been able to find any reference that documents a different runner length, including First's own website. I would expect their own site to point out a shorter runner length. Maybe I've just missed it? Also, just visually, they don't look any different. But if someone can document that the mean length of the runners is measurably shorter, that would be useful to know (don't confuse mean length with the length of the short-side on the inside of the bend!).
In the meantime, remember that the much-increased runner cross section does raise the resonant rpm a little bit, per Helmholz's formula. What I see in posted dyno graphs tells me that the runners are the same length, but just a lot bigger in cross section. It is definitely the best TPI-style intake on the market, but I still don't see it outperforming any short-runner intakes.
Hey nice to see you check back in and stop by! I hope i don't disappoint you and others but I got way in over my head on this post and I'm sorry for that. I'm just a kid in college who's got a lot to learn, even from all of you who's done this way longer, and my 85 got in a wreck cause someone ran me off the road back in the end of may so for now I'm just enjoying the car after it's done getting fixed and saving my money (Had to shed alot of money to help the other insurance who wanted to be cheap and not fix it... ). Sometime in the future when I'm graduated and got the real money coming in I'll throw a miniram and a FIRST intake onto both of my C4s but until then I'm just dreaming and just checking out everyone else's builds! Good luck you and all the rest of you on your builds and I hope you guys thoroughly enjoy them for 230 flywheel HP ole' me!
I am going from memory so I hope it has the first referenced.
OP if you are going to use a FT better call Chris straub or mike jones. Most lifters today are garabge and will go flat.
THey will know which ones will hold up.They arent what they all were 20 yrs ago
My advice is based on simple observational analysis of cost vs reward.
A 100 shot is perhaps 1/100 the cost(time and energy are factors of that cost, not just $$) of what you are planning to do to that old engine, has no bearing on wear and tear if done properly, and will yield extremely similar if not superior results (100 shot = 125 shot = 75 shot = 150 shot for our wide berth analysis these are all the same and achieve the same goal) and we can stop right there.
to continue, with a what if:
what If it dies, and it might not but if it did, you would want the modern drivetrain of the LS as a next replacement (for any old car that is not considered antique original), for it's overdrive and sequential EFI, main girdle and pan support, superior oiling and pcv system, poly component seal design, computer aided modelling, high mileage potential valvetrain, and so forth.
Plus the fact that truck LS engines cost less than the one you have now and also offer two to three times the power capacity if desired.
The LS conversion can be a test of car mastery if done by one self. Thus the attractive nature of such things as a proving grounds.
Can you install the LS in a seamless fashion? Make the car look as though it came with that engine originally? As quiet as a stock unit comes.
With twice or three times the power of a new car as well?
IMO start to weigh the cost vs rewards of your time and efforts more heavily than the sole $$money value of the parts.
In other words think of the situation as if parts cost is negligible (free).
This eliminates the benefit of the LS as a free power plant, which hurts it as a swap option.
Is it still superior in all aspects? Weight, balance, tech, delivery, support, yes.
