85 vacuum line quick question
Removing emissions without knowing what you are doing is downright silly, there are plenty of experienced Corvette Owners that have done it properly. I keep the emissions equipment working on my C4 as I live in a State that does a lot of emissions testing and requires it to all be there during the annual safety inspection.
There should be a diagram under your hood someplace that shows the routing of the Emissions vacuum lines. BTW, it appears that your EGR does not have vacuum line going to it, be sure and check, that might be where the hose was intended to go.
Good Luck getting your Corvette working properly and back on the road!
Chris
Chris
#4 on this diagram
There is a larger vacuum line that runs from the PCV area down to the charcoal canister/valve assembly in this area as well.
#4 on this diagram
that circle looking thing that I circled, I dont know what that is. Seems like a vacuum hose going to it. But on my 85 I dont have anything attached to it from that side. What is it and could that be my problem?
I do recall saying "IF" and I did not say it "WAS" the "EGR" vacuum line. I still see no vacuum line going to the EGR Vacuum Solenoid. No vacuum, no working EGR.
The EGR is directly under the intake manifold and has a vacuum line coming to it from the EGR Vacuum solenoid. There is also a Fuel pressure regulator near the EGR as well and they both have vacuum hoses attached to them. You should be able to identify the EGR valve as its hose goes to the EGR vacuum solenoid. It is usually a smaller walled vacuum line but not always. The Fuel Pressure Regulator is fairly easy to identify as it has screws in a circle holding the diaphragm in place. The EGR does not have all the little screws holding it together.
The EGR can affect the performance of your Corvette if it is not working properly. I am not an expert on the 1985 Model but EGR's have been on cars for decades and I suspect yours is similar to what is on my 1988 C4. The Vacuum solenoid has two wires supplying it with power to activate. The ECM uses PWM to control the EGR. On my 1988 I found out that I had an EGR problem when I had the emissions tested. The NOX was out of sight during the test which indicates the EGR is bad. On my C4 I replaced the EGR, Vacuum Solenoid, Fuel Injectors,FPR, fuel pump and Fuel filter. Cleaning out the blocked EGR passageways was a real PIA and I used carbon remover and wire brushes and air pressure to get all the carbon out. I figured that while I was there I might as well fix this or that so I removed the intake parts and sand blasted them and re-painted the parts. It was a lot of work but worth it in the end.
If you don't have a set already be sure to get yourself a copy of the Factory Service Manuals (my 1988 C4 has two red books and an addendum as well. The manuals are priceless when you have problems with a C4 like the EGR system.
Good Luck and get your Beautiful Corvette back on the road again!
Best regards,
Chris
Best regards,
Chris
All correct. I can post a pic of the EGR vacuum line diagram if Mason123 needs it. Sorry if I dissed you, didn't mean to.
Chris
Best regards,
Chris
my best guess from the OP's original pic is the vacuum line in question goes to the bottom of the throttle body. from the pic, it looks like there is a line going back to a "tee" for the cruise control
in the above pic, hard to tell, but it looks like there are no vacuum lines going to the throttle body...
in the above photo (EGR solenoid) , one of the plastic lines goes to the EGR valve, and the other to the throttle body. at the throttle body, there is a "tee" - it looks like the line in question goes to that "tee." note 1985 is a one year configuration.
here's a pic of my 85. vacuum lines pretty much factory. there should be two 5/32" lines - one goes to the throttle body, and one goes back to a "tee" near the master cylinder - one side goes to the cruise control and the other runs along the firewall the RH-rear plenum.
does the picture at the very top help
questions - do you have anything connected to the vacuum port on the bottom of the throttle body? when was the last time your throttle body was cleaned?
side note: several years ago, I replaced all my rubber vacuum, and emission hoses. made a noticeable difference in my idle quality.
Clean the throttle body and add a can of BG 44K Fuel Injection system cleaner to the fuel tank to clear all the junk out of the system. Do what Joe did and replace every inch of your vacuum lines. The vacuum system is important to your car and it's performance. If that seems overwhelming look at a C3 like my 1968 and the dozens of vacuum hoses all marked with color stripes. That was a nightmare. The only line on the C4 that gave me a fit was the one going to the brake pedal to disengage the cruise control. I have 5 crushed discs in my back and that hurts going under the steering wheel section of the dashboard
The throttle body bushing have a tendency to get looser as the age, check it to be sure it is not another vacuum leak and this one clearly affects your idle.
By the way, Joe C How do you keep your C4 THAT clean? I am always amazed when I see an engine that looks cleaner than when it was brand new. That is some amazing work you do there my friend!
Best Regards,
Chris
