want crank
Old May 10, 2019 | 01:25 PM
top1996's Avatar
top1996
1st Gear
Default want crank
I replace my opti, water pump coil, wires, module, intake gasket, fuel pump and hoses. the car turn over good but want crank. spray a little carb spray in throttle it started, have not check pressure of injectors, any help you have will be wonderful
Old May 10, 2019 | 02:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Next step check FP before and after crank.
Old May 10, 2019 | 03:45 PM
Kevova's Avatar
Kevova
Fuel pressure over 43 psi and should hold when key is turned off. Do you hear fuel pump come on when key is turned to run for 3 sec? You may need helper and listen at fuel filler, if not check for 12v at fuel tank connector.
To want crank
