1993 6 speed trans
Old May 19, 2019 | 11:16 AM
FOCUS124's Avatar
FOCUS124
2nd Gear
Default 1993 6 speed trans
On what side is the filler plug on a 1993 6 speed trans needs to be refilled?
Old May 19, 2019 | 11:35 AM
fake's Avatar
fake
Bottom drivers side, two quarts, fill plug opposite side
Old May 19, 2019 | 05:14 PM
JimLentz's Avatar
JimLentz
Take out filler plug before removing drain plug.
Old May 20, 2019 | 02:06 PM
DGXR's Avatar
DGXR
Fill plug is on the passenger side. The plugs have a torque spec of 26 lb-ft. This is important because they are tapered plugs and can crack the case if severely over-tightened.
Old May 20, 2019 | 06:01 PM
Siveck's Avatar
Siveck
You will need a 17mm Allen hex if you don’t already have one. It will come out easier if the transmission is hot.
To 1993 6 speed trans
