Has anyone done this?
I'm just thinking ,drop a carburated small block and do away with everything that's computerized ,just to keep everything simple.
Of course the nice instrumentation would no longer work and that would be a major job.,but i'm still curious if anyone has done it?
Carb, 6 speed stick and no more computer issues.
Dakota Digital makes a dash conversion to regular analog gauges. There is a kit that shows up on Flee Bay every so often for the gauges.
What am I missing?
But then again, it's your car. If that's what you want to do, then more power to you...have at it!
The value of the car will probably go down after such a swap. Fuel Injection is a step "forward" from carburetors. I have four carburetors for my C3 and use which ever seems appropriate for my planned usage. Trying to maintain a carburetor today is much more challenging with the ethanol issues. The last time I pulled into a shop with a carburetor the mechanics fled as they never touched one before they told me. Mine will not be the "first" for anybody unfamiliar with how they are supposed to work.
I agree with Red86Z51 I would get everything you can online about the system and read them all. Once you get passed the "fear" of fuel injection it is actually a pretty straightforward system to work on.
I found a book by a gentleman named Charles D. Probst at Bentley Publishers called "Corvette Fuel Injection and Electronic Engine Management" and it covers the following fuel injection systems in great detail. It covers the L83, L98, LT1, LT4, LS1, LS6 and the ZR-1. It is a book on "How to Understand, Service and Modify" Corvette fuel injection systems.
Best Regards,
Chris
More Emissions
More Maintenance
Worse Gas Mileage
Less Power
Lower Value of the Car
A lot of work
Why not just sell and buy a C3 if you wan't to be old school?
Also if I break down , I can walk into Auto Zone and for $300 put a new carb on it and drive home. How much is an Map sensor....
When I was out injured for a very long time, after a bad accident - the only cars that ran with no issues were the carb cars.. The 2 computer cars threw codes..
Almost all carbs made after 2000 are ok with the AL in the fuel, check before you buy.
Build the car as you want, but most important drive it and enjoy it. I do....
My truck only went , 37 years and 480,000 miles on it's carburetor before I replaced it. Cost me $400 for the carb and manifold - I upgraded to a 4 barrel. I did the cap and rotor at the same time - $35.00.
It still runs great.
I agree
With that intake I linked above, he can do the same thing with the LT1, Intake, carb, and HEI distributor will eliminate the OPTI, and all of the fuel injection. Dont know for sure, but all of your guages should continue to work as is. The Tach may require some different wiring..... He then would have the LT1 higher lift cam, higher compression, and better flowing heads.vs a SBC swap.
Carburetors have their upsides. Easy to maintain and fix. Thats about it. They're typically worse at everything else.
Joe, I would agree to keep the factory system is probably the best way to go, if, you are keeping the engine stock or close to stock..... (keep in mind the OP has a 92)
But, if he is modifying the motor, ie stroker, etc. Something that is going to require, injectors, bigger throttle body, etc. IMO there is little to like about the 85-95 OBD1 systems.
It is getting harder to find someone who is capable and willing to tune them. And its expensive when you do.
If it is a toy that he occasionally drives, and he wants to make a hotrod out of it, There is some advantages to a intake, carb and hei dist. For $1,000.00 or so.....
Again this is just my opinion, But on a modified motor, I can see advantages to a carb conversion, or something like a holley HP self tuning system, or even a LS swap . But I see little advantage in keeping a OBD1 system on a modified motor, these days....
Oh, one other comment that has been made, "The value of the C4 will be hurt with this mod" Again, my opinion, but most C4 vettes are hard pressed to sell for more then $5,000.00 and probably never will bring much more. As a whole, these are not collector cars, Modify it, make it into what you want and enjoy it!!
Your opinion doesn't reflect the general market when you go to sell a car. Ripping the injection system off and replacing it with anything is going to scare a lot of buyers away.
It pigeon holes the car to only attract a certain type of buyer.
As far as carb running for year and miles... the ability to run and drive is a low bench mark. You are not quantifying how it did on gas mileage, emissions, or if it really made full power as there was nothing there to monitor the performance.
Again, if I were buying an under-$5K C4 that was thrashed, then I might consider going carbed if the engine and electronics were trashed... or actually I'd avoid that car and buy something decent that worked. YMMV.
It was just a question to see if any people have done such a conversion and how they went about it.
My '92 is all original,has about 135k miles on it and it's very well maintained.
Right now it backfires and stumbles from idle but then it accelerates fine.Last summer the code for the EGR came on twice so i hope that's what causing the problem i'm having.
Ordered a new valve and solenoid today,will see if that is all for now.
If i had a bad motor and tranny doing such a swap might make sense but it's not something i'm contemplating,financialy it would cost a ton of money.
I do like the simplicity of the earlier times but we can still work on the C4s without having to take em to a dealer and i do like the idea of getting 25mpg when i drive 200 miles down the coast.
I'm getting better gas mileage (26) than the factory setup, but then again I now have a 6 speed.
I get 25mpg with my 71 and 5 speed.
I needed a map sensor, Mass air flow , cold start injector, IAC, injectors and other crap. It would have cost over $1200. in parts for me to do it. Yes I can do fuel injection, but also remember this is a OB1 computer...
The carb was $275 ( factory re-manufactured) , manifold $125 and the new HELI Distributor was $99. The fuel pressure regulator was $65. All on sale at a local speed shop. That was it, good to go.. Took less than a day.
It's now as reliable as my 67, 71 and 72. almost forgot my 1980 truck... turn the key and go
I should have said IAC or MAFS. , after you figure out what it was... my bad..
Most people think a 1000 CFM carburetor will make them faster, if they chose the proper size and type for the street - their cars would run better - like a 600 CFM on a SBC 350.
