Radio Model
Old May 28, 2019 | 08:51 AM
Michael Thauer's Avatar
Michael Thauer
3rd Gear
Default Radio Model
Hello. Can anybody say, if the Bose Gold Series CD / CA Radio modelnumber 16160761 will fit in a 91 C 4?
Greets from Germany
Michael
Old May 29, 2019 | 06:23 PM
WVZR-1's Avatar
WVZR-1
Greets from Germany
Michael
I believe that it would 'FIT' but it wouldn't be correct. The buttons/bezel/face are different. The # you mention is most often mentioned for '92 & 93 (black vs dk gray). It also wouldn't be an EU export tuner. That # seems to be a US tuner. I mentioned that only because you mentioned Germany. Does the car have Bose presently? If it's only base Delco (now) there's way more required other than just the control head.
To see the visual difference eBay GM 16144151 (DK GRAY) vs the 16160761 (BLACK) - there seems to be both there presently. One of the 16144151 is incorrectly mentioned to also do '92 & '93, .but should be only correct for '90 & '91.
Old May 30, 2019 | 07:09 AM
Michael Thauer
3rd Gear
[QUOTE=WVZR-1;1599488739]I believe that it would 'FIT' but it wouldn't be correct. The buttons/bezel/face are different. The # you mention is most often mentioned for '92 & 93 (black vs dk gray). It also wouldn't be an EU export tuner. That # seems to be a US tuner. I mentioned that only because you mentioned Germany. Does the car have Bose presently? If it's only base Delco (now) there's way more required other than just the control head.
To see the visual difference eBay GM 16144151 (DK GRAY) vs the 16160761 (BLACK) - there seems to be both there presently. One of the 16144151 is incorrectly mentioned to also do '92 & '93, .but should be only correct for '90 & '91.[/QUOTE
Thanks for your answer. I have the Bose Gold Series presently with an aftermarket radio. So, I just try it out.
Greets
Michael
To Radio Model
