If you don't use heads with the internal "crossover" ports, and you try to convert to the external EGR style, you'll fail the visual of the smog test. Can you even buy aluminum heads with peripheral valve cover hold down bolts? Fail again! Here's some iron head info for you:
If you don't use heads with the internal "crossover" ports, and you try to convert to the external EGR style, you'll fail the visual of the smog test. Can you even buy aluminum heads with peripheral valve cover hold down bolts? Fail again! Here's some iron head info for you: https://www.youtube.com/watch?v=uvmlKF5dr18
Visual in CA is vicious! They even crawl under my car to check the part number on my cat!
Visual in California is everything; I've passed smog tailpipe with cams that were "too big" and compression ratios that were "too high" and surprisingly those engines passed without a problem; but the visual is another story.
