Shiftlights: What's a good setup?
Old Nov 6, 2002 | 07:22 PM
FastVette94's Avatar
FastVette94
Default Shiftlights: What's a good setup?
I'm running the stock ignition/tach but I want to use a shiftlight because my motor pulls to 6500 (stock tach ends at 6000).
Do I have to use an MSD control box to hook up a tach? Can I tie in somewhere? I want to use a mini-shift light if possible.
Old Nov 6, 2002 | 07:33 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Default Re: Shiftlights: What's a good setup? (FastVette94)
Try this one out.
http://www.hashmarks.com/ShiftLight/index.html
Old Nov 6, 2002 | 07:35 PM
95AquaC4's Avatar
95AquaC4
Harlan seems to be the light of choice. I think you have to bypass the tach filter. Someone will chime in soon with better info!!
Old Nov 6, 2002 | 08:07 PM
FastVette94
Default Re: Shiftlights: What's a good setup? (95AquaC4)
I will have to bypass the tach filter on a 94?
Old Nov 6, 2002 | 08:34 PM
Nathan Plemons's Avatar
Nathan Plemons
I have a harlan shift light in my 92. I've got it mounted in the vent as in the website above. I'm very happy with it so far.
I installed mine using the tach output from my MSD box, but you can use the factory tach output. I don't think you'll have to bypass the tach filter but I don't know for sure. Mine is bypassed but that is because of the MSD, not the shift light. :cheers:
Old Nov 6, 2002 | 11:41 PM
ELEVENS's Avatar
ELEVENS
Yo! Same exact story here - 6K tack, shift mid-6K's. Went with the MSD mini, controlled by a seperate MSD RMP-activated switch. About 1/2" x 3", it's unobtrusive on the steering column but pleny bright - even in sunlight. The RPM-activated switch get it's signal from the tach output of my MSD-6AL, and takes those goofy plug-in "pills". Some guys actually hide the mini light in an HVAC vent, but me thinks it's waaay too :cool: to hide. Very happy with this setup.
:seeya :cheers:
Old Nov 7, 2002 | 12:23 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Shiftlights: What's a good setup? (Nathan Plemons)
Go for the Red Harlan. No pills just dip switches to adjust RPM. :cool:
Old Nov 7, 2002 | 08:07 AM
RichS's Avatar
RichS
Default Re: Shiftlights: What's a good setup? (85vet)
I use the Harland light and I'm happy with it. :cheers:
Old Nov 7, 2002 | 12:23 PM
Arisa's Avatar
Arisa
Default Re: Shiftlights: What's a good setup? (RichS)
Harland :yesnod: :yesnod: :yesnod:
Old Nov 7, 2002 | 12:28 PM
93Blackrose's Avatar
93Blackrose
Harlan Shiftlight here too! :yesnod:
[Modified by 93Blackrose, 4:29 PM 11/7/2002]
Old Nov 7, 2002 | 01:45 PM
STL94LT1's Avatar
STL94LT1
Default Re: Shiftlights: What's a good setup? (93Blackrose)
Another vote for Harlan.
Old Nov 11, 2002 | 10:51 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Shiftlights: What's a good setup? (STL94LT1)
Another vote for the Harlan form way over here... :)
Old Nov 11, 2002 | 10:56 AM
lead_foot's Avatar
lead_foot
Harlan shift light installed in vent. Works great. Only trick is getting itto saty in the posistion you want. I just used some small pieces of rubber to wedge it in position. Any other method to hold it in place?
To Shiftlights: What's a good setup?
